Chinatown Dump Submitted
ionblue
Re: Chinatown Dump Submitted
Post by ionblue »
SamuriHL wrote: Sat Jan 18, 2025 9:06 pm Looks like someone added it to the KEYDB. You can use my tool to synchronize the KEYDB and copy it to the MakeMKV data directory:
viewtopic.php?f=12&t=16883&p=166510#p166510
Yeah except that’s for Windows. I’ve been meaning to put something together for Mac to do this, but habit round to it.
Post by SamuriHL »
I haven't had time to work on a Mac version, either. Maybe one of these days. Of course, that means you'd have to grab the keydb directly instead of using FindVUK to sync it, but that's really not an issue.
cbuteau
Post by cbuteau »
Updating the keydb.cfg did not work for me.
I can't seem to attach the dump I have.
MrPenguin
Post by MrPenguin »
cbuteau wrote: Wed Dec 24, 2025 9:43 pm I can't seem to attach the dump I have.
Try uploading your TGZ dump file into (say) OneDrive or Google Drive, and then replying with a public download link.
cbuteau
Post by cbuteau »
MrPenguin
Post by MrPenguin »
cbuteau wrote: Tue Dec 30, 2025 6:17 pm Okay.
Thanks. The good news is that the latest KEYDB.cfg file already contains a complete entry for your disk. The bad news is that your drive has not enabled LibreDrive, which means that MakeMKV cannot disable bus encryption:
SDF  v0a3: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MOELC2F1134
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130306
DEBUG: Code 0 at JP0V,W`B0e43*0h<e5:213131686
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Have you ever managed to rip a UHD disk using this drive? You might need to flash its firmware to make it compatible with LibreDrive.
