UHD FAQ
Re: UHD FAQ
#61 Post by SamuriHL » Sun Jan 19, 2025 12:33 am
Thanks for the feedback. I'll take a look and fix that in the next update.
Re: UHD FAQ
#62 Post by SamuriHL » Sun Jan 19, 2025 12:39 am
That bug should be fixed in the new update I just posted. Thanks again!
PaulCB
Re: UHD FAQ
#63 Post by PaulCB » Mon Jan 20, 2025 4:43 am
Thanks SamuriHL, that could be a nice little time saver. Did get windows controlled folder access all mad by trying to write to Documents but but that is expected as it is set to block this sort of thing by default. Had no complaints about pulling down the file and putting the keydb in the MakeMKV folder.
But what isn't good is that it thinks "FindVUK.exe" is a virus and quarantined it Trojan:Win32/Wacatac.B!ml Any thoughts on why it might be triggering it?
Re: UHD FAQ
#64 Post by SamuriHL » Mon Jan 20, 2025 4:56 am
I got the same thing. It's a false positive. I've been using that version of findvuk since it came out and this is like the third time it's been flagged. My code is pulling it from the findvuk website directly so it's nonsense. Just ignore it.
Sent from my SM-S928U1 using Tapatalk
PaulCB
Re: UHD FAQ
#65 Post by PaulCB » Mon Jan 20, 2025 5:18 am
Ok. So when I got the pop-up, I just went ahead and put in my bank account, social security number, mother's maiden name... :D
I went to the doom9 thread and saw the conversation about it there. Seems to be all good.
(for anyone else wanting to read it: https://forum.doom9.org/showthread.php?t=172472&page=43)
Re: UHD FAQ
#66 Post by SamuriHL » Mon Jan 20, 2025 11:15 am
Like I said it happens a lot. I just whitelist it each time. I could create a version without findvuk but it does a really good job on differential updates and I'm lazy. Lmao
ictbydesign
Re: UHD FAQ
#67 Post by ictbydesign » Fri Feb 28, 2025 7:36 am
how do i uninstall this, it does not show anywhere, (KeyDB_Helper).
Thanks.
PaulCB
Re: UHD FAQ
#68 Post by PaulCB » Fri Feb 28, 2025 6:24 pm
"how do i uninstall this" You delete the files. It never installed so you don't need to uninstall.
ictbydesign
Re: UHD FAQ
#69 Post by ictbydesign » Sat Mar 01, 2025 9:28 am
PaulCB wrote: Fri Feb 28, 2025 6:24 pm "how do i uninstall this" You delete the files. It never installed so you don't need to uninstall.
Thanks, i did find this out in the end, on one device it put a folder on the desktop and on another it didn't.
microfast
Re: UHD FAQ
#70 Post by microfast » Sun Mar 30, 2025 4:23 pm
SamuriHL wrote: Fri Jan 17, 2025 2:43 pm KeyDB Helper (Windows Only)
https://www.mediafire.com/file/7cs6ppux ... .2.7z/file
Hi Samury,
Thanks a lot for your helper :)
Will be possibile have a helper that simply do the syncronize without show nothing and then exit?
Kind regards
Re: UHD FAQ
#71 Post by SamuriHL » Sun Mar 30, 2025 8:48 pm
microfast wrote: Sun Mar 30, 2025 4:23 pm
Hi Samury,
Kind regards
I have no plans to add that no. Sorry.
Re: UHD FAQ
#72 Post by SamuriHL » Sun Apr 20, 2025 1:51 am
Those who read my KeyDB Helper post very carefully could be rewarded. ;) I've updated it to include some new functionality using both FindVUK under the covers and the keydb.cfg file itself once it's downloaded by FindVUK. Enjoy :D
Re: UHD FAQ
#73 Post by SamuriHL » Tue Apr 22, 2025 3:28 pm
I just released a new version of the KeyDB Helper. I left some debug logging in place in the last release by mistake and it causes the log to grow very quickly. I highly recommend grabbing this release.
Re: UHD FAQ
#74 Post by SamuriHL » Fri Apr 25, 2025 12:33 am
One more update for the KeyDB Helper. This one locally validates the unit key(s) for your disc and if the locally validated data doesn't match the keydb, it updates the keydb entry for your disc and runs a findvuk validatedisc to update the entry. This allows people to fix bad entries in the keydb.
Toad King
Re: UHD FAQ
#75 Post by Toad King » Fri Apr 25, 2025 2:05 am
SamuriHL wrote: Fri Apr 25, 2025 12:33 am One more update for the KeyDB Helper. This one locally validates the unit key(s) for your disc and if the locally validated data doesn't match the keydb, it updates the keydb entry for your disc and runs a findvuk validatedisc to update the entry. This allows people to fix bad entries in the keydb.
Does it also run findvuk validatedisc for entries with (LEGACY) and/or (NOTVALIDATED) in the comment? Might be useful to run it for those as well.
