Chinatown Dump Submitted
chazphx
Post by chazphx »
MKB20_v77_Chinatown_E93E
Thank you!
MrPenguin
Re: Chinatown Dump Submitted
Post by MrPenguin »
chazphx wrote: Thu Jan 16, 2025 9:11 pm MKB20_v77_Chinatown_E93E
chris.maness24
Post by chris.maness24 »
I have the same problem with Chinatown. I downloaded last night and still could not get it to run. It created a dump, I'm happy to post it to if that would be helpful.
MrPenguin
Post by MrPenguin »
chris.maness24 wrote: Fri Jan 17, 2025 3:08 pm It created a dump, I'm happy to post it to if that would be helpful.
Yes, I believe some here would find that file useful ;).
chris.maness24
I just emailed it to svq@makemkv.com. Hopefully all that is all I need to do. I haven't done this before.
outlier
Post by outlier »
Updating the keydb.cfg didn't help with this title (I emailed a dump to svq a few days ago).
Initially running "FindVUK - Synchronize" didn't help with "Once Upon a Time in the West", but turns out that's because I had updated the batch file to also copy the result to MakeMKV's directory and hadn't noticed that when an update was automatically installed in Sept 2024 it reverted the changes I had made to the batch file.
Post by SamuriHL »
viewtopic.php?f=12&t=16883&p=166510#p166510
You can use my new tool to keep the keydb updated and copied to MakeMKV. It'll also check your disc and see if it's in the keydb.
chris.maness24
I had two new movies. Once upon a time in the west and Chinatown. Neither worked but I updated the keydb (1/16 version) and Once upon a time in the west worked but Chinatown still will not work.
Post by SamuriHL »
The KEYDB is constantly updated. This is why I wrote my helper program to keep things updated and to also see if your title is in the KEYDB after you sync. Sync the KEYDB then put the disc in and press the Disc Info button and it'll show you if there's a key entry for your disc.
Posting a link or attaching the dump file MAY allow others to add the disc to the KEYDB.
chris.maness24
Here is my dump file. Thanks for any assistance.
MKB20_v77_Chinatown_E93E.tgz
(3.42 MiB) Downloaded 329 times
Post by SamuriHL »
Awesome. Hopefully the right people see it and are able to help.
ionblue
Post by ionblue »
Submitted one today as well. Still isn’t in the keydb file downloaded earlier today.
Post by SamuriHL »
Looks like someone added it to the KEYDB. You can use my tool to synchronize the KEYDB and copy it to the MakeMKV data directory:
chris.maness24
Looks like it is in the latest one I downloaded this afternoon. :-)
ionblue
Post by ionblue »
Damn. Must have been after I downloaded it. I’ll do it again.
