Dump submitted - Cure (1997) UK 4K UHD
dump file MKB20_v77_CURE_4K_2B64.tgz emailed
Re: Dump submitted - Cure (1997) UK 4K UHD
Could you also upload that dump as an attachment here please? Or maybe upload it into (say) Google Drive or OneDrive, and then reply with a link?
Sure, attached
keydb_helper
Support for your disc has been added to the public keydb.
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
