My Best Friend's Wedding
neo305
Post by neo305 »
what am i doing wrong that i still can't open this disc 2 years later?
Getting disc info...
[DiscID]: 0xB9EC65332E3814900699D95D86379667504302EE
[Volume]: MY_BEST_FRIENDS_WEDDING
[Title]: MY BEST FRIEND'S WEDDING
[Date]: 2022-11-04
[MKB]: 77
[EncKey]: 1-0x3A13D878ACB67E46FD693E1819E932FA
[DiscType]: UHD
KEYDB Entry:
[Title]: My Best Friend's Wedding 4K Ultra HD
[Date]: 2022-11-04
[UnitKey]: 1-0xDC1596C7274418AA15E93C89F2A4F604
MrPenguin
Re: My Best Friend's Wedding
Post by MrPenguin »
neo305 wrote: Fri Jan 17, 2025 4:02 pm what am i doing wrong that i still can't open this disc 2 years later?
Dumps, dumps, glorious dumps... ;)
That disk will need a Volume ID, so the best dump to share would be a non-Pioneer one.
Post by SamuriHL »
That title only has a unit key. MakeMKV requires a VUK to be in the keydb entry in order to be able to use it. You can open the disc with something like XReveal or you can wait until MakeMKV supports the disc (assuming you've sent in your disc dump) or you can post a link to the MakeMKV dump so that someone can add it to the keydb with a VUK.
(EDIT: On another note, perhaps I should flag that condition in my tool. That'd be handy)
Post by SamuriHL »
I updated my tool to determine if the KeyDB entry can be used by MakeMKV or not. You'll see a [MakeMKV SUPPORTED] line with TRUE or FALSE.
neo305
Post by neo305 »
Awesome thanks. Yeah I believe I sent the tgz file in for review. Also I have the first file from 2 years ago and the one now and they are different names and size but was same disc. Weird. Well I just sent the recent one since was only like 300kb and original was 3mb
keydb_helper
Post by keydb_helper »
neo305 wrote: Fri Jan 17, 2025 4:22 pm Awesome thanks. Yeah I believe I sent the tgz file in for review. Also I have the first file from 2 years ago and the one now and they are different names and size but was same disc. Weird. Well I just sent the recent one since was only like 300kb and original was 3mb
Your variant of My Best Friend's Wedding now has a complete entry in the public keydb. This means it can be used with MakeMKV now if you download and configure the public keydb.cfg file to complement MakeMKV's native UHD support.
Public KeyDB Disc Submissions
neo305
Post by neo305 »
keydb_helper wrote: Sat Jan 18, 2025 3:55 am
Awesome thank you so much for this :)
