AACS 2.1 support
keydb_helper
Re: AACS 2.1 support
Post by keydb_helper »
roopdoge wrote: Fri Jan 17, 2025 1:07 am Here is the dump file.
Sorry, what do you mean by disk info?
Thanks for providing the disc dump.
Your disc does not utilise AACS 2.1, it is standard AACS 2.0.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
roopdoge
Post by roopdoge »
keydb_helper wrote: Fri Jan 17, 2025 7:06 am
Thank you for clarifying. Must have looked too quickly!
The right side of make mkv just copy paste the text under disc info
Attachments don't work on the forum
bitjunkie
Post by bitjunkie »
Disk-Informationen
Label: Heretic
Zeitstempel: 2025-01-19 22:09:17
Schutz: AACS2.0/C v77
Datenkapazität: 60.51 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 2
Markierungen der Bus-Verschlüsselung: 80
bitjunkie wrote: Fri Mar 28, 2025 3:28 pm Disk-Informationen
Label: Heretic
Anzahl der Layer: 2
Please email the dump file to svq@makemkv.com.
Read more in the hashed keys section of the UHD FAQ.
MrPenguin
Post by MrPenguin »
Label: Heretic
This dump file has nothing to do with AACS v2.1.
Have you tried downloading the latest KEYDB.cfg, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
chris996
Post by chris996 »
There is only one UHD movie (Mission Impossible II) from my collection
that has not been decoded and I do not want to give up :)
There is no hash key for this UHD movie in the KEYDB.cfg file.
Can you create one for me?
Disc Information
Label: MISSION IMPOSSIBLE II
Timestamp: 2018-08-23 12:52:26
Protection: AACS2.0/C v65
Data capacity: 58.71 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
BTW. Where is the dump file on the hard disk?
Post by d00zah »
chris996 wrote: Thu Apr 10, 2025 2:02 pm ...
Disc Information
Number of layers: 2
IF Windows, try looking in the default location... %UserProfile%\.MakeMKV
MakeMKV will report the location of the dump when it generates it.
chris996
Post by chris996 »
Maybe a stupid question, but where to send a dump file from MakeMKV?
MakeMKV created two files. And where to send AACS directory from UHD movie?
If I can send them by email, that would be great.
chris996 wrote: Thu Apr 10, 2025 5:51 pm Maybe a stupid question, but where to send a dump file from MakeMKV?
There's the UHD FAQ which answers lots of questions.
chris996
Post by chris996 »
OK, I send a dump file via email - movie Mission Impossible II UHD.
keydb_helper
The upcoming release of Fury utilises AACS 2.0 instead of AACS 2.1. I think it is the second or third title to drop AACS 2.1 when re-issued.
KeyDB Priority List
Post by SamuriHL »
It really does seem like they've completely deprecated it. Mike had said it was really expensive for them to create titles using it and that it was done in pairs. Given that all but one title was able to be backed up, it seems the expense wasn't worth it to them. Good. Lol
katsura2
Post by katsura2 »
Hello
Can someone help to brake The UHD LEGEND OF FONG SAI YUK FRENCH UDH FACTORIS FILMS
Thank you
This disk isn't a "2.1" disk; it just hasn't got a key yet.
Did you email the .TGZ file to svq@makemkv.com so a key can be created? Are you downloading keys, for when it is (it may have already been created)?
