Jackie Brown Dump Submitted
Ralph P.
Post by Ralph P. »
Greetings,
MKB20_v77_Jackie_Brown_18FA
The file has also been loaded to Google Drive for Keydb.
Regards,
Ralph P.
Re: Jackie Brown Dump Submitted
Post by Ralph P. »
Greetings,
This title now rips using the latest Keydb file. Thank you!
Regards,
HanSolo551
Post by HanSolo551 »
Weird this dump isn't working for my Jackie Brown Disc.
MrPenguin
Post by MrPenguin »
HanSolo551 wrote: Tue Jan 21, 2025 6:59 pm Weird this dump isn't working for my Jackie Brown Disc.
gentile2226
Post by gentile2226 »
I have submitted MKB20_v77_JACKIE_BROWN_UHD_90FC.tgz which is the British release.
Edit: Downloading the latest KEYDB didn't fix the issue.
keydb_helper
Post by keydb_helper »
gentile2226 wrote: Sat Mar 29, 2025 2:07 pm I have submitted MKB20_v77_JACKIE_BROWN_UHD_90FC.tgz which is the British release.
Could you share a link to this disc dump with the forum?
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
gentile2226
keydb_helper wrote: Sat Mar 29, 2025 2:32 pm
I don't think it'll be helpful to you because I have an unflashed Pioneer drive but here you go: https://www.mediafire.com/file/pci0m1b8 ... C.tgz/file
Post by SamuriHL »
Sadly I don't think that'll be a helpful image. Is that the only drive you have?
gentile2226
SamuriHL wrote: Sat Mar 29, 2025 7:13 pm Sadly I don't think that'll be a helpful image. Is that the only drive you have?
Yes I'm afraid so
