The Amityville Horror (1979) 88 Films
endlessblockade
#1 Post by endlessblockade » Wed Jan 15, 2025 4:11 am
MKB20_v77_THE_AMITYVILLE_HORROR_A70C
There is an entry for this in the keydb but it looks like it has a different disc id.
cinemaslavejoe
Re: The Amityville Horror (1979) 88 Films
#2 Post by cinemaslavejoe » Fri Jan 17, 2025 3:38 am
I just submitted a report for this disc today myself. Good times.
MrPenguin
#3 Post by MrPenguin » Fri Jan 17, 2025 10:59 am
cinemaslavejoe
#4 Post by cinemaslavejoe » Fri Jan 17, 2025 11:28 pm
So I did that, and it didn't fix it... but I just double-checked, and I copied the file to the wrong directory. :oops: I moved it the right place, restarted MakeMKV, and now it's working fine. Thanks very much!
#5 Post by SamuriHL » Fri Jan 17, 2025 11:38 pm
If you're on windows, use this going forward:
viewtopic.php?f=12&t=16883&p=166510#p166510
Whenever you want to update the KeyDB, use the synchronize button and it'll automatically copy it to the proper MakeMKV directory for you.
