National Lampoon's Vacation UHD (2023) Failed to Open Disc
kdubbs29
Post by kdubbs29 » Wed Jan 15, 2025 4:22 am
I am getting the following error when trying to open National Lampoon's Vacation (2023) UHD:
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Saved AACS dump file as /Users/kevinwerther/Library/MakeMKV/MKB20_v77_National_Lampoon's_Vacation_A5BE.tgz
DEBUG: Code 0 at w^wtY%u{44AL>mFw:213132721
DEBUG: Code 0 at w^wtY%u{44AL>mFw:213131341
Additional drive info:
OS device name: /dev/rdisk4
Product: BD-RE BU40N
Revision: 1.00
Serial number: XXXXXXXXX
Firmware date: 2116-12-20 15:28
Highest AACS version: 77
Firmware version: 1.00
Disc Information
Label: NATIONAL_LAMPOONS_VACATION
Timestamp: 2023-04-25 13:49:45
Protection: AACS2.0/C v77
Data capacity: 60.76 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
I have emailed the .tgz file to svq@makemkv.com. I have manually added the KEYDB.cfg file to my username>Library>MakeMKV folder on my Mac. It looks like that KEYDB.cfg file contains the key to this specific disc, but isn't working.
I have successfully ripped/backed up several other UHDs before, so not sure why this one is giving me trouble. I cleaned the disc as well. Does anyone have any ideas? Should I just wait and trust that svq@makemkv.com will make some sort of an update in the next few days? Thank you in advance for your help!
MrPenguin
Re: National Lampoon's Vacation UHD (2023) Failed to Open Disc
Post by MrPenguin » Wed Jan 15, 2025 3:44 pm
kdubbs29 wrote: Wed Jan 15, 2025 4:22 am I am getting the following error when trying to open National Lampoon's Vacation (2023) UHD:
Interesting. More help might be possible if someone here could examine your TGZ dump file. Could you attach it to a reply please? Or maybe upload it to (say) Google Drive or OneDrive, and then reply with a link?
neo305
Post by neo305 » Wed Jan 15, 2025 4:43 pm
Ever find a solution for this? I’m having same problem with Snowpiercer
kdubbs29
Post by kdubbs29 » Wed Jan 15, 2025 8:21 pm
MrPenguin wrote: Wed Jan 15, 2025 3:44 pm
I'll try to send a link later tonight when I get home from work. Hopefully someone will be able to make heads or tails of it. Thanks!
kdubbs29
Post by kdubbs29 » Wed Jan 15, 2025 8:23 pm
neo305, no answer yet. Let me know if you get an answer on your issue. Maybe it will have the same solution.
kdubbs29
Post by kdubbs29 » Wed Jan 15, 2025 10:28 pm
Ok, here is a link to download my tgz file. Maybe someone can make heads or tails of it. Thanks! https://we.tl/t-3zjOdAy3D9
Post by SamuriHL » Wed Jan 15, 2025 11:26 pm
That disc has an entry in the keydb so it definitely should be working with the keydb in the right location.
[DiscID]: 0x4FDE36C5C2C22EDABA82550D38D3A1565C8162A2
kdubbs29
Post by kdubbs29 » Wed Jan 15, 2025 11:56 pm
SamuriHL wrote: Wed Jan 15, 2025 11:26 pm That disc has an entry in the keydb so it definitely should be working with the keydb in the right location.
Yeah. Any ideas why it might NOT be working for me, given the info I posted at the top of the thread?
Post by SamuriHL » Wed Jan 15, 2025 11:59 pm
Unsure. You could try using XReveal and see if that works with the keydb to decrypt the disc. At least then you could open it with MakeMKV in theory.
As for the keydb.cfg file, you have to make sure you extract it from the zip file to the MakeMKV data directory, which is where the tgz files are created. Once you do that, restart MakeMKV and it should, in theory, work.
MrPenguin
Post by MrPenguin » Thu Jan 16, 2025 12:39 am
kdubbs29 wrote: Wed Jan 15, 2025 11:56 pm Yeah. Any ideas why it might NOT be working for me, given the info I posted at the top of the thread?
Maybe a silly question, but does your copy of KEYDB.cfg actually contain the entry for DiscId 0x4FDE36C5C2C22EDABA82550D38D3A1565C8162A2?
kdubbs29
Post by kdubbs29 » Thu Jan 16, 2025 3:44 am
MrPenguin wrote: Thu Jan 16, 2025 12:39 am
Hmmm... no, it does not. It does have an entry for Nat'l Lamp Vac 2023, but it must be a different version. I tried pasting that DiscID into my cfg file and restart MakeMKV, but it didn't make a difference. There is a chance I am not doing it correctly.
kdubbs29
Post by kdubbs29 » Thu Jan 16, 2025 3:47 am
SamuriHL wrote: Wed Jan 15, 2025 11:59 pm Unsure. You could try using XReveal and see if that works with the keydb to decrypt the disc. At least then you could open it with MakeMKV in theory.
I had extracted the KEYDB.cfg file from the zip, and placed it in the correct directory. And unfortunately, it does not work.
XReveal appears to be only for PC, and I'm on a Mac. :(
kdubbs29
Post by kdubbs29 » Thu Jan 16, 2025 4:11 am
kdubbs29 wrote: Thu Jan 16, 2025 3:44 am
Great news! Looks like there is a newer KEYDB.cfg file out there that now has the key. I replaced my file from yesterday, and now the disc is being read!!! Fingers crossed I don't run into any more snags, but at least now things look to be normal. Thank you all so much for all of your help!
Post by SamuriHL » Thu Jan 16, 2025 4:14 am
Just for future reference the keydb is updated real-time throughout the day. It's constantly being updated. So downloading it once it's not going to be sufficient for newer titles.
Sent from my SM-S928U1 using Tapatalk
kdubbs29
Post by kdubbs29 » Thu Jan 16, 2025 1:12 pm
SamuriHL wrote: Thu Jan 16, 2025 4:14 am Just for future reference the keydb is updated real-time throughout the day. It's constantly being updated. So downloading it once it's not going to be sufficient for newer titles.
That makes total sense. I've never needed to download it prior to this.
1) Going forward, should I delete the KEYDB.cfg from my MakeMKV folder (I don't believe it was in that folder prior to this mess)?
2)I have my preferences set to enable internet access, so will that cover me going forward if I do delete the KEYDB.cfg file?
