Snowpiercer Dump submitted (US SteelbooK)
MKB20_v77_Snowpiercer_A5D6.tgz
Toad King
Re: Snowpiercer Dump submitted (US SteelbooK)
Same disc. Submitted to KeyDB and it should now work with that.
DiscID: 0x1584C300D51A54AAC7FF6A93EC2A63D24D3ADA7F
AngryVirginian
How does one submit to KeyDB?Toad King wrote: Wed Jan 15, 2025 2:14 am Same disc. Submitted to KeyDB and it should now work with that.
Toad King
Check your PMs.AngryVirginian wrote: Wed Jan 15, 2025 2:22 amHow does one submit to KeyDB?Toad King wrote: Wed Jan 15, 2025 2:14 am Same disc. Submitted to KeyDB and it should now work with that.
neo305
Same here how do I rip this?AngryVirginian wrote:How does one submit to KeyDB?Toad King wrote: Wed Jan 15, 2025 2:14 am Same disc. Submitted to KeyDB and it should now work with that.
garnuts
That worked, Thanks!Toad King wrote: Wed Jan 15, 2025 2:14 am Same disc. Submitted to KeyDB and it should now work with that.
neo305
MrPenguin
Download the latest KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV?
neo305
kdubbs29
Can you PM me how to submit as well? I think it might help solve an issue I'm having with a different UHD disc. Thanks!!!Toad King wrote: Wed Jan 15, 2025 2:38 amCheck your PMs.AngryVirginian wrote: Wed Jan 15, 2025 2:22 amHow does one submit to KeyDB?Toad King wrote: Wed Jan 15, 2025 2:14 am Same disc. Submitted to KeyDB and it should now work with that.
MrPenguin
Allowing people to examine your disk's TGZ dump file is likely to be a Good First Stepkdubbs29 wrote: Wed Jan 15, 2025 8:25 pm Can you PM me how to submit as well? I think it might help solve an issue I'm having with a different UHD disc. Thanks!!!
You should obviously email your dump file to svq@makemkv.com as well, of course.
kdubbs29
Thanks! I have started a separate thread for my movie issue (National Lampoon's Vacation 2023), so I don't want to be duplicative here. But just in case, here is a link to my tgz issue: https://we.tl/t-3zjOdAy3D9MrPenguin wrote: Wed Jan 15, 2025 9:11 pmAllowing people to examine your disk's TGZ dump file is likely to be a Good First Stepkdubbs29 wrote: Wed Jan 15, 2025 8:25 pm Can you PM me how to submit as well? I think it might help solve an issue I'm having with a different UHD disc. Thanks!!!. Either as an attachment here, or uploading it into Google Drive or OneDrive and then replying with a link.
