LibreDrive for Pioneer drives
Forget it.
If you feel it is possible, why have you not done it?
For the "average user", replacing the soldered-on chip to make it so that you can copy UHD disks seems excessive, but, if you're not an "average user", there is nothing preventing you from doing it.
I'm not sure what holds the fw the 128 pin chip or the other one you mentioned.boogiewoogie16787 wrote: Wed Jan 08, 2025 9:44 pm
Woodstock made it sound like in his last post that someone has already confirmed that desoldering and replacing chip works which is why I was open to doing it, my point was that its not a skills gap for me.
Is it confirmed that the renesas R8j32740fp42 has firmware?
I have not heard of many vendors putting firmware inside the main MCU as it normally increases the cost of production significantly.
Xbox 360 designers did this after they were compromised and the cost became worth it: https://youtu.be/U7VwtOrwceo?t=342
Would Pioneer do this? They are not custom vendor with too much chip design capability right? They buy mostly off the shelf parts like everyone else. The renesas chip, the motor control IC, everything else is off the shelf. Maybe the renesas chip had built in feature for flash (if confirmed that it has the flash)
Found this (looks like someone here probably took these pics): https://imgur.com/a/jMDrp0V
If you scroll all the way to the bottom pics you will see IC402 which is that AR15F6 chip. Looks like flash chip?
Anyway has someone already tried swapping chips with an old drive to see if it works?
How about reversing the flash program to see why it refuses to accept old firmware?
Me and Marty tried some stuff with the flashers it always results in a soft brick we assume it's something like LG did with a downgrade check in the fw before it will flash as even if you force it to flash the drive soft bricks the only way is if someone knows how to decrypt the fw and can understand what's in it or like you say and off board programer but again do we need to put unencrypted fw on it? We don't have any of that
snowkitten
Hi
Is it possible for me to enable UHD reading on my drive, as i can see i have the old firmware... If i put in an UHD disk it just after a while tell me there is no disk.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ...
Firmware date: 2017-06-22
Highest AACS version: 63
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Thanks in advance.
Revision: 3.10
Serial number: ...
Thanks in advance.
boogiewoogie16787
It would be nice to have some avenue to rescue new Pioneer drives and if this is possible then thats cool. If no one has actually successfully done it then fine thats understandable but Woodstock said in his original message, "If you replaced the chips, you could do it, but how many people want to desolder/solder chips?"Woodstock wrote: Wed Jan 08, 2025 10:27 pm If you feel it is possible, why have you not done it?
Look I need two things: A diagram of which chip to take off and the make/model of the programmer used to reprogram the chip. I can then do it.
Well the way he/she phrased it sounds like someone has done it and confirmed working. Have they or haven't they? If they have great, point me to a diagram/link and then i'll buy a drive and do it.
And if this method does work than you guys got yourself another small business opportunity: Reprogramming chips by mail. People can send you chips and you can flash them.
boogiewoogie16787
Ah very interesting! Thank you for the additional information!
https://diy-optics.com/products/laser-i ... on-service
https://www.outermost-tech.com/portal/t ... psulation/
Just putting these links out there in case anyone else is also crazy.
Not sure if we would get enough resolution but it would give us a good indication of if the chip is flash or not.
If the Renesas is a multi chip module (which if it does hold flash it could be) then maybe theres an opportunity to do another hack like the Kamikaze hack done on the 360.
Have you seen scanlime's videos discussing how she is reversing a Samsung Blueray drive? Her goal is not to break the encryption but to repurpose the drive for an art project. Still it goes into interesting techniques on making sense of firmware files, its 8 years old but still relevant: https://youtu.be/UTUYl-2g-r4?t=281
I really like how she loaded the firmware file into Photoshop of all tools and it allowed her to gather many insights into the structure of the file.
Because I am crazy, I was considering maybe getting a bad drive off of ebay, taking that AR15F6 off and sending it to one of these places:Billycar11 wrote: Wed Jan 08, 2025 11:59 pm I'm not sure what holds the fw the 128 pin chip or the other one you mentioned.
Sounds really cool! Thats awesome that you guys tried! I've been reading about decompilation but i've been focused on trying to help decompile old video games. My C knowledge is rusty from my CS days and I do Angular/Python coding at my job so its hard to master low level stuff unless I sacrifice all my free time. Its really hard so I appreciate the efforts you guys have dome!Billycar11 wrote: Wed Jan 08, 2025 11:59 pm Me and Marty tried some stuff with the flashers it always results in a soft brick we assume it's something like LG did with a downgrade check in the fw before it will flash as even if you force it to flash the drive soft bricks the only way is if someone knows how to decrypt the fw and can understand what's in it or like you say and off board programer but again do we need to put unencrypted fw on it? We don't have any of that
No never seen it but I put it on my watch list.boogiewoogie16787 wrote: Thu Jan 09, 2025 3:58 am Ah very interesting! Thank you for the additional information!
Sounds really cool! Thats awesome that you guys tried! I've been reading about decompilation but i've been focused on trying to help decompile old video games. My C knowledge is rusty from my CS days and I do Angular/Python coding at my job so its hard to master low level stuff unless I sacrifice all my free time. Its really hard so I appreciate the efforts you guys have dome!Billycar11 wrote: Wed Jan 08, 2025 11:59 pm Me and Marty tried some stuff with the flashers it always results in a soft brick we assume it's something like LG did with a downgrade check in the fw before it will flash as even if you force it to flash the drive soft bricks the only way is if someone knows how to decrypt the fw and can understand what's in it or like you say and off board programer but again do we need to put unencrypted fw on it? We don't have any of that![]()
I don't see the decaping service doing any good
You never know when pioneers with old fw will no longer be available if you don't have one get a 212v ud04 or 03 and just email me for the flasher for now those can all still be flashed those are the last retail ones that can.
If you want the latest gen the only option is me Marty or asmcom.
krakenbruins
Hey all,
Very new to all of this and learning on the go. Managed to get a Pioneer BDR-XD07UHD with a Firmware date of Aug. 2020, and would be much appreciative of some assistance in flashing it.
OS device name: H:
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Bus encryption flags: 13
Drive platform: RS8D31
Firmware version: 1.03/ID05
From everything I have read, the Firmware date looks ok, just concerned about the Drive Platform and how (if needed) to get it to MT1959, then what firmware version it should be flashed to. Thanks in advance!
OS device name: H:
Revision: 1.03
Serial number: ...
Should work as is do not flash it**Scam Web Site** wrote: Fri Jan 10, 2025 10:40 pm Hey all,
OS device name: H:
Revision: 1.03
Serial number: ...
MrPenguin
That's easy - DON'T FLASH IT!**Scam Web Site** wrote: Fri Jan 10, 2025 10:40 pm Very new to all of this and learning on the go. Managed to get a Pioneer BDR-XD07UHD with a Firmware date of Aug. 2020, and would be much appreciative of some assistance in flashing it.
If you do then your drive will almost certainly NEVER be able to read UHDs again.
whatexactlydoyoudo
I think there is a firmware that supports this particular Pioneer BDR-UD03 floating around somewhere, can anyone help me locate it?
Product: BD-RW BDR-UD03
Revision: 1.21
Serial number: ...
Firmware date: 2018-04-26
Highest AACS version: 75
Firmware version: ID19
truskino
Hi Mike,
is Pioneer BDR-X13J-X still not yet Libredrive enabled?
Looking forward to hearing from you.
Sincerely,
Luca
Product: BD-RW BDR-X13JX
Revision: 1.04
Serial number: ...
Firmware date: 2023-08-01
Highest AACS version: 76
Firmware version: ID72
Disc Information
Label: THOR_LOVE_AND_THUNDER
Timestamp: 2022-08-09 12:57:43
Protection: AACS2.0/C v70
Data capacity: 55.79 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Sincerely,
Luca
Revision: 1.04
Serial number: ...
Disc Information
Number of layers: 2
PM sent.whatexactlydoyoudo wrote: Sat Jan 11, 2025 8:41 pm I think there is a firmware that supports this particular Pioneer BDR-UD03 floating around somewhere, can anyone help me locate it?Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.21 Serial number: ... Firmware date: 2018-04-26 Bus encryption flags: 1B Highest AACS version: 75 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID19
Your firmware is too new. Return it if you still can.truskino wrote: Sun Jan 12, 2025 3:41 pm Hi Mike,
Sincerely,
Luca
Revision: 1.04
Serial number: ...
Disc Information
Number of layers: 2
whatexactlydoyoudo
Thanks! Got it all flashed and ripping UHD discs. But good grief was it ever a process in a USB enclosure..Coopervid wrote: Sun Jan 12, 2025 7:38 pmPM sent.whatexactlydoyoudo wrote: Sat Jan 11, 2025 8:41 pm I think there is a firmware that supports this particular Pioneer BDR-UD03 floating around somewhere, can anyone help me locate it?Code: Select all
