Hy,
thanks to add this to makemkv.
MKB20_v77_ROUND_MIDNIGHT_UHD_D3EE.tgz
Round midnight (autour de minuit)
Re: Round midnight (autour de minuit)
The TGZ file will only remain until the other people download it. If your intent was to have it picked up directly be MakeMKV, you emailed it to svq@makemkv.com , correct?
This TGZ dump file was created using a Verbatim 43888, and so has an unreadable Volume ID (VID)
For the record, your D3EE variant has this DiscId:
0xF2080891E477DAAD61BD876890824E3882DBDB76Re: Round midnight (autour de minuit)
Looks like the unit key has been uploaded to the keydb. You'd need to use XReveal to utilize the unit key but if you use XReveal and then open MakeMKV you can process your disc.
Thanks, with Xreveal, i succeed to make a backup of my uhd disc, after an update of the keydb.cfg.
This is still not working for me.
I have attached the created D3EE tgz file.
Thanks for checking.
keydb_helper
Thanks for the disc dump. Your variant of Round Midnight now has a complete record in the public keydb. If you redownload the latest keydb.cfg file MakeMKV will be able to process your disc.rufus1856 wrote: Mon Jan 13, 2025 10:40 am This is still not working for me.
Public KeyDB Disc Submissions
Thank you, this is working now.
