Round midnight (autour de minuit)
tt1270
Post by tt1270 »
Hy,
thanks to add this to makemkv.
MKB20_v77_ROUND_MIDNIGHT_UHD_D3EE.tgz
Re: Round midnight (autour de minuit)
The TGZ file will only remain until the other people download it. If your intent was to have it picked up directly be MakeMKV, you emailed it to svq@makemkv.com , correct?
MrPenguin
Post by MrPenguin »
tt1270 wrote: Thu Jan 09, 2025 5:27 am MKB20_v77_ROUND_MIDNIGHT_UHD_D3EE.tgz
This TGZ dump file was created using a Verbatim 43888, and so has an unreadable Volume ID (VID) :(. Would you happen to have access to another UHD drive please?
For the record, your D3EE variant has this DiscId:
0xF2080891E477DAAD61BD876890824E3882DBDB76
Post by SamuriHL »
Looks like the unit key has been uploaded to the keydb. You'd need to use XReveal to utilize the unit key but if you use XReveal and then open MakeMKV you can process your disc.
tt1270
Post by tt1270 »
Thanks, with Xreveal, i succeed to make a backup of my uhd disc, after an update of the keydb.cfg. :)
rufus1856
Post by rufus1856 »
This is still not working for me.
I have attached the created D3EE tgz file.
Thanks for checking.
keydb_helper
Post by keydb_helper »
rufus1856 wrote: Mon Jan 13, 2025 10:40 am This is still not working for me.
Thanks for the disc dump. Your variant of Round Midnight now has a complete record in the public keydb. If you redownload the latest keydb.cfg file MakeMKV will be able to process your disc.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
rufus1856
Post by rufus1856 »
Thank you, this is working now.
