Submitted dump named:
MKB20_v77_YOJIMBO_9500
Dump Submitted - Yojimbo UHD
keydb_helper
Re: Dump Submitted - Yojimbo UHD
A UHD variant Yojimbo has been added to the public keydb. It may work with your disc.
(libaacs disc ID is 0x0B68692ABB1B39CD3BD903DCD448ACE3F2A9CDD2)
Public KeyDB Disc Submissions
Is it possible to pull the disk id from a disk in my drive? I am trying to extract Yojimbo and it is stating that the volume key is unknown.
I did just restart MakeMKV and it downloaded the latest public key file.
Yes, you just need to calculate the SHA1 hash of the disk's AACS/Unit_Key_RO.inf file. On Linux, you'd use the sha1sum tool to do this. On Windows, you could try:mikew1998 wrote: Wed Jan 15, 2025 11:15 pm Is it possible to pull the disk id from a disk in my drive?
certutil -hashfile "AACS\Unit_Key_RO.inf" SHA1-
keydb_helper
MakeMKV does not automatically download the public keydb. MakeMKV automatically downloads its own proprietary "hashed key" database but these two key databases support different titles. If you'd like to use the public keydb for titles not yet supported by MakeMKV, check out my post here.mikew1998 wrote: Wed Jan 15, 2025 11:15 pm I did just restart MakeMKV and it downloaded the latest public key file.
