Top Gun 4k two pack
loathvirtual drives
Top Gun 4k two pack
#1 Post by loathvirtual drives » Wed Jan 08, 2025 1:40 am
MKB20_v76_Top_Gun-_Maverick_F481.tgz
trying to rip mavrick 4k two pack two tries get this error
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
loathvirtual drives
Re: Top Gun 4k two pack
#2 Post by loathvirtual drives » Wed Jan 08, 2025 1:59 am
bump
#3 Post by Woodstock » Wed Jan 08, 2025 3:11 am
Posting the TGZ file on the forum does no good for MakeMKV; the author only uses emailed files... Assuming you (or someone else) emailed the file.
It is useful for other people who create alternative decoding methods, like keydb, which is why I allow the posts to sit for a few days before removing the attachment (yours has been downloaded twice so far).
Bumping does nothing for that.
Assuming you have the automatic download of keys enabled (sometimes that is problematic; there are threads about that), trying every few days is the recommended method, unless you also want to try downloading the alternative decoding keys. Usually, someone posts the link to that fairly quickly, once they have the key.
#4 Post by SamuriHL » Wed Jan 08, 2025 3:26 am
It's already in the keydb.
Sent from my SM-S928U1 using Tapatalk
MrPenguin
#5 Post by MrPenguin » Wed Jan 08, 2025 11:09 am
Your disk already has this entry in KEYDB:
0x3B1F1C99717AFCB91DC16C3B9DB46791B6887D26 = TOP_GUN_MAVERICK (Top Gun: Maverick) | D | 2022-08-02
