Top Gun 4k two pack
loathvirtual drives
Top Gun 4k two pack
Post by loathvirtual drives »
MKB20_v76_Top_Gun-_Maverick_F481.tgz
trying to rip mavrick 4k two pack two tries get this error
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
loathvirtual drives
Re: Top Gun 4k two pack
bump
Posting the TGZ file on the forum does no good for MakeMKV; the author only uses emailed files... Assuming you (or someone else) emailed the file.
It is useful for other people who create alternative decoding methods, like keydb, which is why I allow the posts to sit for a few days before removing the attachment (yours has been downloaded twice so far).
Bumping does nothing for that.
Assuming you have the automatic download of keys enabled (sometimes that is problematic; there are threads about that), trying every few days is the recommended method, unless you also want to try downloading the alternative decoding keys. Usually, someone posts the link to that fairly quickly, once they have the key.
Post by SamuriHL »
It's already in the keydb.
Sent from my SM-S928U1 using Tapatalk
MrPenguin
Post by MrPenguin »
loathvirtual drives wrote: Wed Jan 08, 2025 1:40 am The volume key is unknown for this disc - video can't be decrypted
Your disk already has this entry in KEYDB:
0x3B1F1C99717AFCB91DC16C3B9DB46791B6887D26 = TOP_GUN_MAVERICK (Top Gun: Maverick) | D | 2022-08-02
