Dump Submitted - Yojimbo UHD
Nocobo
#1 Post by Nocobo » Tue Jan 07, 2025 10:44 pm
Submitted dump named:
MKB20_v77_YOJIMBO_9500
keydb_helper
Re: Dump Submitted - Yojimbo UHD
#2 Post by keydb_helper » Wed Jan 08, 2025 8:25 am
Nocobo wrote: Tue Jan 07, 2025 10:44 pm Submitted dump named:
A UHD variant Yojimbo has been added to the public keydb. It may work with your disc.
(libaacs disc ID is 0x0B68692ABB1B39CD3BD903DCD448ACE3F2A9CDD2)
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
mikew1998
#3 Post by mikew1998 » Wed Jan 15, 2025 11:15 pm
Is it possible to pull the disk id from a disk in my drive? I am trying to extract Yojimbo and it is stating that the volume key is unknown.
I did just restart MakeMKV and it downloaded the latest public key file.
MrPenguin
#4 Post by MrPenguin » Wed Jan 15, 2025 11:22 pm
mikew1998 wrote: Wed Jan 15, 2025 11:15 pm Is it possible to pull the disk id from a disk in my drive?
Yes, you just need to calculate the SHA1 hash of the disk's AACS/Unit_Key_RO.inf file. On Linux, you'd use the sha1sum tool to do this. On Windows, you could try:
certutil -hashfile "AACS\Unit_Key_RO.inf" SHA1
keydb_helper
#5 Post by keydb_helper » Thu Jan 16, 2025 12:45 am
mikew1998 wrote: Wed Jan 15, 2025 11:15 pm I did just restart MakeMKV and it downloaded the latest public key file.
MakeMKV does not automatically download the public keydb. MakeMKV automatically downloads its own proprietary "hashed key" database but these two key databases support different titles. If you'd like to use the public keydb for titles not yet supported by MakeMKV, check out my post here.
KeyDB Priority List
