Greetings,
Just picked up a BU40N. It has Rom Version 1.02 with a manufacturer date of March 2024. It will be installed in an Asus Windows 11 Pro PC (slim type). Is there any reason to believe that the firmware isn't encrypted? I will be using the latest version of SDF Tool.
New LG BU40N - Question Before Flashing
Re: New LG BU40N - Question Before Flashing
BU40N 1.02 should be encrypted. Pretty much all LG/ASUS firmware dated 2020+ (2120 in MakeMKV) is encrypted.Ralph P. wrote: Tue Jan 07, 2025 9:53 pm Greetings,
Ralph P.
Greetings,MartyMcNuts wrote: Tue Jan 07, 2025 10:11 pmBU40N 1.02 should be encrypted. Pretty much all LG/ASUS firmware dated 2020+ (2120 in MakeMKV) is encrypted.Ralph P. wrote: Tue Jan 07, 2025 9:53 pm Greetings,
Got it. Thanks Marty!
Regards,
Ralph P.
Greetings,
The drive is in, flashed and currently ripping away. I do like the fact that it is faster than my Pioneer drive. Thanks again to all.
Regards,
Regards,
MrPenguin
I've never used my own BU40N drive for ripping, but I have discovered one UHD disk that it struggles to mount. Whereas my Pioneer drive mounts this same UHD disk easily, albeit reads it more slowly than other disks.Ralph P. wrote: Wed Jan 08, 2025 3:18 pm I do like the fact that it is faster than my Pioneer drive.
Ralph P.
Greetings,MrPenguin wrote: Wed Jan 08, 2025 3:43 pmI've never used my owb BU40N drive for ripping, but I have discovered one UHD disk that it struggles to mount. Whereas my Pioneer drive mounts this same UHD disk easily, albeit reads it more slowly than other disks.Ralph P. wrote: Wed Jan 08, 2025 3:18 pm I do like the fact that it is faster than my Pioneer drive.
The BU40N does seem to take longer to mount than the Pioneer. I noticed that it identifies the disc as a BD Rom rather than by title versus the Pioneer. No biggie there.
Regards,
Wash the disc. LGs are sensitive to that invisible film on new discs.Ralph P. wrote: Wed Jan 08, 2025 4:24 pmGreetings,MrPenguin wrote: Wed Jan 08, 2025 3:43 pmI've never used my owb BU40N drive for ripping, but I have discovered one UHD disk that it struggles to mount. Whereas my Pioneer drive mounts this same UHD disk easily, albeit reads it more slowly than other disks.Ralph P. wrote: Wed Jan 08, 2025 3:18 pm I do like the fact that it is faster than my Pioneer drive.
Regards,
Ralph P.
Coopervid wrote: Wed Jan 08, 2025 4:35 pmWash the disc. LGs are sensitive to that invisible film on new discs.Ralph P. wrote: Wed Jan 08, 2025 4:24 pmGreetings,MrPenguin wrote: Wed Jan 08, 2025 3:43 pm
Regards,
Greetings,
Got it, thanks. I just tried another title and it loaded faster and identified the disc. All good either way.
Regards,
