twisters UHD issue
Johno4566
twisters UHD issue
Post by Johno4566 »
hi i am getting error
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=067EFCA8EA7E)
Saved AACS dump file as C:\Users\ben/.MakeMKV/MKB20_v77_Twisters_4E84.tgz
thanks
MrPenguin
Re: twisters UHD issue
Post by MrPenguin »
Johno4566 wrote:
Sun Jan 05, 2025 10:58 pm
Johno4566
Post by Johno4566 »
i tryed that and did not seem to work
thanks
Are you sure MakeMKV's HK download is working on your system?? Because the key for your disc was generated months ago. I submitted it myself and ripped it a few days later. viewtopic.php?p=161618#p161618
Johno4566
Post by Johno4566 »
not sure
all i know i ripped boarderlands uhd today and worked fine
Johno4566 wrote:
Mon Jan 06, 2025 3:40 am
not sure
Did you have a HK download today? I did when I used MakeMKV earlier today. You would have seen the message in the log window.
