Dump Submitted - Babylon 5 The Road Home 4k
Goros
Post by Goros »
MKB20_v77_Babylon_5-_The_Road_Home_70EC.tgz
MrPenguin
Re: Dump Submitted - Babylon 5 The Road Home 4k
Post by MrPenguin »
Goros wrote: Tue Dec 31, 2024 8:50 pm MKB20_v77_Babylon_5-_The_Road_Home_70EC.tgz
Goros
Post by Goros »
That link is dead, so no.
Tried it from another few threads, if you ctrl+f5 it its gone./
MrPenguin
Post by MrPenguin »
Goros wrote: Tue Dec 31, 2024 10:00 pm That link is dead, so no.
That link to KEYDB.cfg is most certainly not dead...
I would recommend installing KEYDB.cfg as I described, and then trying to decrypt all of your disks again.
Goros
Post by Goros »
Ok so explain this to me like I'm a window licker.
On my PC browser, your KEYDB.cfg in your posts shows up as an active link to https://fvonline-db.bplaced.net/ which auto redirects to a non-https site and throws a 404 error, as does the homepage link ON the 404 page.
No matter what I do, it won't connect to https:// only http which has a 404.
Got a mega link or a google drive or something? github? anything but that link?
MrPenguin
Post by MrPenguin »
Goros wrote: Tue Dec 31, 2024 10:19 pm On my PC browser, your KEYDB.cfg in your posts shows up as an active link to https://fvonline-db.bplaced.net/ which auto redirects to a non-https site and throws a 404 error, as does the homepage link ON the 404 page.
That website does not support https://. It only supports http://. Are you using Chrome as your browser?
Only this can work: http://fvonline-db.bplaced.net
Goros
Post by Goros »
Yeah chrome no addons incognito mode etc.
Here's how I got it to work:
ProtonVPN, securecore ON, Killswitch On.
right-click, save as.
open the html file, right click the english database, save as and then the zip magics its way onto my pc
that was harder than it should be.
MrPenguin
Post by MrPenguin »
Goros wrote: Tue Dec 31, 2024 10:35 pm Yeah chrome no addons incognito mode etc.
No, it shouldn't be that hard. I'm sure you can configure Chrome to allow certain websites still to use http://, but I use Firefox by default.
