Has anyone ripped this disc? I see a dump file was sent a month ago.
viewtopic.php?f=12&t=34443
I downloaded the online key, and it looks like the key is there?
0xA62AE142D8C5C1FC9731E0E8E70A15483AD915F0 = MINISTRY_UNGENTLEMANLY_WARFARE (The Ministry Of Ungentlemanly Warfare - Ultra HD Blu-ray™) | D | 2024-05-02 | V | 0x69C77EEEB0B49291126EDE98D4DA721B | M | 0x264E780075D00DF840D6396A4A25FBE2 | I | 0x262F6C8419959E75C932F9B78895A913 | U | 1-0x48AF9BD3703FFFDA0EEEC9F5CB2D9361 ; MKBv77/BEE - VolumeSize: 85371453440 (UHD) (LEGACY) (NOTVALIDATED) (BD)
The Ministry of Ungentlemanly Warfare 4k unable to copy
jt5298
tribunal88
Re: The Ministry of Ungentlemanly Warfare 4k unable to copy
I just got this for Christmas and its failing with the following error:
DEBUG: Code 0 at VtT$hoa+N}'B:VS3:29398070
Saved AACS dump file as d:\Users\<usernam>/.MakeMKV/MKB20_v77_The_Ministry_Of_Ungentlemanly_Warfare_D8A0.tgz
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?tribunal88 wrote: Fri Dec 27, 2024 10:10 pm I just got this for Christmas and its failing with the following error:
tribunal88
richwill
I also received a copy of this at Christmas and have been unable to decrypt it. I checked the hash of the Unit_Key_RO.inf (CAD8FDA6528FE6A6D08D2DFC18B935CE16E0242B) and confirmed it's not in the most recent keydb.cfg.
I emailed the tgz file a few times, but no update. I'm only using linux, and don't have access to run FindVUK at this point. I could potentialy install Windows somewhere just for this, but if someone has solved this, it would be great.
Thanks to help here, the key was added. Thanks again!
MrPenguin
FindVUK works fine on Linux using Wine's wineconsole.richwill wrote: Tue Jan 21, 2025 9:19 pm I'm only using linux, and don't have access to run FindVUK at this point.
richwill
I will dig into running FindVUK locally. Thanks for that tip as well!
MrPenguin
No worries. BTW you don't need DVDFab in order to run either "findvuk synchronize" or "findvuk validateDisc".richwill wrote: Wed Jan 22, 2025 2:49 pm I will dig into running FindVUK locally. Thanks for that tip as well!
