I wanted to put my UHDs on HD so that I can watch them better in my home cinema. I bought the drive from Pioneer (BD-RW BDR-UD04) with firmware 1.14. (see attachment)
With makemkv i should activate the "Enable Internet" button, which I did.
Unfortunately, with every UHD it gives me an error message saying that it cannot open the disc.
There is an internet connection, the check mark is set and I also stopped the virus protection once for testing purposes.
What can I do or what am I doing wrong? Please help a noob!
by the way: blu-ray ripping works fine
Newbie with UHD, every UHD failed
Panikmike
- 1.JPG (37.68 KiB) Viewed 3200 times
- 2.JPG (31.1 KiB) Viewed 3200 times
Re: Newbie with UHD, every UHD failed
The error message says that it cannot decode the disk, and that it created a dump of the information about it. That implies that the disk was not in your database yet...
Enabling internet does not necessarily mean that your system was able to contact the server with the information. A lot of internet providers will block DNS inquiries for the host that provides the information, and some will block actually contacting them. Have you read the topic about this yet?
MrPenguin
As an aside, have you also tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV? This could at least provide a "short term" solution.Panikmike wrote: Tue Dec 31, 2024 1:32 pm Unfortunately, with every UHD it gives me an error message saying that it cannot open the disc.
Panikmike
I try to download it, but it sais - Site is not available (error 404). I try to find it, but i failed. I also thought that is a short solution for me, but i cant find the KEYDB.cfg somewhere :/MrPenguin wrote: Tue Dec 31, 2024 3:19 pmAs an aside, have you also tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV? This could at least provide a "short term" solution.Panikmike wrote: Tue Dec 31, 2024 1:32 pm Unfortunately, with every UHD it gives me an error message saying that it cannot open the disc.
Panikmike
No but i will do it now, thank youWoodstock wrote: Tue Dec 31, 2024 2:04 pm The error message says that it cannot decode the disk, and that it created a dump of the information about it. That implies that the disk was not in your database yet...
Goros
I got this exact same error, even using protonvpn with securecore and killswitch to multiple different countries.Panikmike wrote: Tue Dec 31, 2024 1:32 pm
Right click his link - saveas to your desktop as an html file.
Then when its saved, open it and then download the engilish pack the same way you downloaded this.
then unzip that file and drop it into the correct folder.
