Fall Guy Dumps Sent
Toby2k
Re: Fall Guy Dumps Sent
German Disc is working
Dumps submitted for both the Theatrical version and Extended Cut discs from the Aussie Steelbook Edition.
Theatrical: MKB20_v77_FALLGUY_UPK1_D1BC
Extended Cut: MKB20_v77_FALLGUY_UPK50_2994
UHDRip1337
MKB20_v77_The_Fall_Guy_-_Extended_Cut_DDE4 sent
Both of these are working now after today's update.MartyMcNuts wrote: Tue Aug 06, 2024 4:42 am Dumps submitted for both the Theatrical version and Extended Cut discs from the Aussie Steelbook Edition.
darthtye
Just want to 2nd that updating to newest version fixed issue even if change log said "Version bump, no changes". Something must have changed.
youley
Dump sent
MKB20_v77_FALLGUY_UPK1_AB16: Fall Guy Theatrical Cut
MrPenguin
Have you tried copying the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
youley
Now working in MakeMKV, and with keydb.cfg
Toxillo
I have the UHD Extended Cut (FALLGUY_UPK50) of Fall Guy and the Verbatim 43888 (LG BU40N inside) but I can't get the main playlist off the disc. I have the most recent keydb.cfg which fixed the decryption errors and enabled me to get all the short stuff off. But for the main playlist it eventually shows a hash error, around 26GB in.
I saw someone who had the same issue with the same drive fix it by getting a different USB-C cable. Is that something worth trying? Unfortunately, I don't know the specs of the cables I have lying around.
The drive itself is pretty new, I only got it in February and it had no problems with the UHD Oppenheimer.
Has anyone had a similar issue with the Verbatim 43888/LG BU40N and managed to fix it?
A hash check error generally means the drive is having trouble reading a spot on the disc. The disc might be dirty, even if it is brand new and just out of the package. A gentle cleaning is often helpful. Sometimes a drive might need more power than it is currently getting. This is sometimes a problem with portable, USB powered drives like your BU40N.Toxillo wrote: Mon May 18, 2026 3:41 pm I have the UHD Extended Cut (FALLGUY_UPK50) of Fall Guy and the Verbatim 43888 (LG BU40N inside) but I can't get the main playlist off the disc. I have the most recent keydb.cfg which fixed the decryption errors and enabled me to get all the short stuff off. But for the main playlist it eventually shows a hash error, around 26GB in.
