Transformers One - Dump Submitted
dawg_ripper
Re: Transformers One - Dump Submitted
Post by dawg_ripper »
its working now. thank you!
tv261
Post by tv261 »
Please pardon this question from a newbie, I tried searching for "submit TGZ" and didn't receive a response. How do I submit a TGZ file? I have a Transformers One BD with a MKBv81. The KEYDB.cfg file from yesterday didn't work.
I think most everywhere you look, "submit TGZ" mentions the address svq@makemkv.com to send it to. That gets it to the author of MakeMKV for processing.
MrPenguin
Post by MrPenguin »
tv261 wrote: Sat Dec 28, 2024 4:44 am Please pardon this question from a newbie, I tried searching for "submit TGZ" and didn't receive a response. How do I submit a TGZ file? I have a Transformers One BD with a MKBv81. The KEYDB.cfg file from yesterday didn't work.
MakeMKV should be able to decrypt ordinary (i.e. non-UHD) BluRays without creating a dump file to submit, and also without needing KEYDB.cfg. Does MakeMKV's log contain any messages about not being able to download anything, or not connecting to a remote server?
tv261
Post by tv261 »
MrPenguin wrote: Sun Dec 29, 2024 12:51 am
I don't have errors. I try to make my own disc images as backups. VLC won't play the image without an updated KEYDB.cfg file.
MrPenguin
Post by MrPenguin »
tv261 wrote: Sun Dec 29, 2024 10:30 pm I don't have errors. I try to make my own disc images as backups. VLC won't play the image without an updated KEYDB.cfg file.
If your disk uses bus encryption then your backup disk image will not be usable even with a suitable KEYDB.cfg file, and all UHD disks use bus encryption. Some ordinary BD disks use it too. Can you tell me what the SHA-1 hash of the disk's AACS/Unit_Key_RO.inf file is please? E.g. by executing
sha1sum AACS/Unit_Key_RO.inf
Edit:
And it looks like the ordinary BD of "Transformers One" does indeed use bus encryption:
0xB92FC273DC90135808D465A98F77AB341B63D40D = TRANSFORMERS_ONE (Transformers One) | D | 2024-09-18 | ... ; MKBv81/BEE/FindVUK 1.79 - VolumeSize: 40216559616 (BD)
You will need to use MakeMKV's "back-up" option to create your disc images, because this will remove the bus encryption. And if you tell MakeMKV to create a decrypted backup then VLC should have no difficulty playing it.
tv261
Post by tv261 »
MrPenguin wrote: Mon Dec 30, 2024 12:26 am
Edit:
Thanks for telling me. I haven't seen anything about this before, but I went looking into this after your comment. It looks like I need to reconsider how I do my backups. This program is definitely worth the price.
