Dump Submitted - The Searchers - 4K_UHD
Fast Fizzy
Post by Fast Fizzy » Thu Dec 26, 2024 3:47 am
Dump file submitted 12/25.
code DEFC
I wondered why this has not shown up anywhere.
keydb_helper
Re: Dump Submitted - The Searchers - 4K_UHD
Post by keydb_helper » Thu Dec 26, 2024 4:40 am
code DEFC
The DFEC variant of The Searchers was submitted to the public keydb yesterday. I think it should work with your disc unless there are two variants with remarkably similar MakeMKV IDs.
Public KeyDB Disc Submissions
Fresca
Post by Fresca » Sat Dec 28, 2024 2:02 am
code DEFC
Just tried to rip my disc and it didn't open and dumped a tgz as well which I just emailed in. Not sure what's going on then.
keydb_helper
Post by keydb_helper » Sat Dec 28, 2024 5:14 am
Are you using the public keydb? If not, you'll have to wait until MakeMKV supports your particular disc.
MrPenguin
Post by MrPenguin » Sat Dec 28, 2024 11:34 am
Could you post the full name of your dump file, please? There are often many different variants of each title, and we need the file name to know whether you have a variant that no-one here has seen yet.
Fresca
Post by Fresca » Sat Dec 28, 2024 10:18 pm
MKB20_v77_The_Searchers_-_4K_UHD_DFEC.tgz is what dumped and what I emailed.
MrPenguin
Post by MrPenguin » Sat Dec 28, 2024 10:23 pm
OK, so that should be the disk that KEYDB already has. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
wocket
Post by wocket » Mon Dec 30, 2024 5:50 pm
Thank you for that. I was having the same problem with same key and that worked. Do I leave the downloaded KEYDB in that folder or delete it when done?
Elephen
Post by Elephen » Mon Dec 30, 2024 7:17 pm
I wasn't able to update the KEYDV.cfg file, so I'm posting here. Thanks.
MrPenguin
Post by MrPenguin » Mon Dec 30, 2024 7:46 pm
AFAICT your dump file matches this existing entry in KEYDB:
0x9F43210F647B62CF4D8BBBCC48B0790FFFDDC37B = The Searchers UHD (The Searchers - 4K UHD) | D | 2024-12-25
So if you copy the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV then you should be able to decrypt your disk.
Elephen
Post by Elephen » Mon Dec 30, 2024 10:13 pm
Your suggestion worked fine. Thank you.
