Dump submitted - Léon (The Professional) spanish
javicozarcastillo
Post by javicozarcastillo » Sat Dec 28, 2024 5:24 pm
File attached: MKB20_v77_LEON_1C78.tgz
Thanks!!
MrPenguin
Re: Dump submitted - Léon (The Professional) spanish
Post by MrPenguin » Sun Dec 29, 2024 12:03 pm
javicozarcastillo wrote: Sat Dec 28, 2024 5:24 pm File attached: MKB20_v77_LEON_1C78.tgz
The latest KEYDB.cfg file contains this entry:
0x60806F8345CCE8ED8DD0835A3D459C0954A1E9DE = LEON | D | 2024-09-30
which should match your 1C78 variant. Have you tried downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
javicozarcastillo
Post by javicozarcastillo » Mon Dec 30, 2024 8:47 am
I didn't try, in fact didn't knew how it works this whole thing. After I've read your post I've done some research, downloaded the CFG file, and bingo, it all works perfect!!!
Thank you so much for your kind advice, without your post I'd still be stuck in the same point.
Have a good 2025 and, again, thank you!!!!
MrPenguin
Post by MrPenguin » Mon Dec 30, 2024 2:47 pm
javicozarcastillo wrote: Mon Dec 30, 2024 8:47 am I didn't try, in fact didn't knew how it works this whole thing. After I've read your post I've done some research, downloaded the CFG file, and bingo, it all works perfect!!!
No worries, but to be clear - KEYDB is an alternative optional database that MakeMKV can use, if available. Your key will also appear in MakeMKV's own "hashed keys" database at some point.
