Transformers One - Dump Submitted
dawg_ripper
Re: Transformers One - Dump Submitted
its working now. thank you!
tv261
Please pardon this question from a newbie, I tried searching for "submit TGZ" and didn't receive a response. How do I submit a TGZ file? I have a Transformers One BD with a MKBv81. The KEYDB.cfg file from yesterday didn't work.
I think most everywhere you look, "submit TGZ" mentions the address svq@makemkv.com to send it to. That gets it to the author of MakeMKV for processing.
MrPenguin
MakeMKV should be able to decrypt ordinary (i.e. non-UHD) BluRays without creating a dump file to submit, and also without needing KEYDB.cfg. Does MakeMKV's log contain any messages about not being able to download anything, or not connecting to a remote server?tv261 wrote: Sat Dec 28, 2024 4:44 am Please pardon this question from a newbie, I tried searching for "submit TGZ" and didn't receive a response. How do I submit a TGZ file? I have a Transformers One BD with a MKBv81. The KEYDB.cfg file from yesterday didn't work.
tv261
I don't have errors. I try to make my own disc images as backups. VLC won't play the image without an updated KEYDB.cfg file.MrPenguin wrote: Sun Dec 29, 2024 12:51 amMakeMKV should be able to decrypt ordinary (i.e. non-UHD) BluRays without creating a dump file to submit, and also without needing KEYDB.cfg. Does MakeMKV's log contain any messages about not being able to download anything, or not connecting to a remote server?tv261 wrote: Sat Dec 28, 2024 4:44 am Please pardon this question from a newbie, I tried searching for "submit TGZ" and didn't receive a response. How do I submit a TGZ file? I have a Transformers One BD with a MKBv81. The KEYDB.cfg file from yesterday didn't work.
MrPenguin
If your disk uses bus encryption then your backup disk image will not be usable even with a suitable KEYDB.cfg file, and all UHD disks use bus encryption. Some ordinary BD disks use it too. Can you tell me what the SHA-1 hash of the disk's AACS/Unit_Key_RO.inf file is please? E.g. by executingtv261 wrote: Sun Dec 29, 2024 10:30 pm I don't have errors. I try to make my own disc images as backups. VLC won't play the image without an updated KEYDB.cfg file.
sha1sum AACS/Unit_Key_RO.infAnd it looks like the ordinary BD of "Transformers One" does indeed use bus encryption:
0xB92FC273DC90135808D465A98F77AB341B63D40D = TRANSFORMERS_ONE (Transformers One) | D | 2024-09-18 | ... ; MKBv81/BEE/FindVUK 1.79 - VolumeSize: 40216559616 (BD)-
tv261
Thanks for telling me. I haven't seen anything about this before, but I went looking into this after your comment. It looks like I need to reconsider how I do my backups. This program is definitely worth the price.MrPenguin wrote: Mon Dec 30, 2024 12:26 amIf your disk uses bus encryption then your backup disk image will not be usable even with a suitable KEYDB.cfg file, and all UHD disks use bus encryption. Some ordinary BD disks use it too. Can you tell me what the SHA-1 hash of the disk's AACS/Unit_Key_RO.inf file is please? E.g. by executingtv261 wrote: Sun Dec 29, 2024 10:30 pm I don't have errors. I try to make my own disc images as backups. VLC won't play the image without an updated KEYDB.cfg file.Edit:Code: Select all
And it looks like the ordinary BD of "Transformers One" does indeed use bus encryption:You will need to use MakeMKV's "back-up" option to create your disc images, because this will remove the bus encryption. And if you tell MakeMKV to create a decrypted backup then VLC should have no difficulty playing it.Code: Select all
