Dump Submitted for Ghost Rite Here Rite Now
MrNinjaShock
Post by MrNinjaShock »
MKB20_v77_Ghost_Rite_Here_Rite_Now_-_Ultra_HD™_2D_Feature_Disc_BCC6
rhummer
Re: Dump Submitted for Ghost Rite Here Rite Now
Post by rhummer »
Dump submitted for MKB20_v77_Ghost_Rite_Here_Rite_Now_-_Ultra_HD™_2D_Feature_Disc_ECB4
Shockmaindave
Post by Shockmaindave »
Have either of you had any luck getting this yet?
I also submitted a dump via email on 12/13, and I'm trying to be patient because I know this is shareware, but I can't wait to see this!
rhummer
Post by rhummer »
Yes, I got a new cfg on Tuesday and it was able to decrypt.
Shockmaindave
Strange, I have the same ECB4 code but I'm not able to decrypt it. Any suggestions? And is it awesome?
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=1F08FC37E75B)
Saved AACS dump file as C:\Users\dave/.MakeMKV/MKB20_v77_Ghost_Rite_Here_Rite_Now_-_Ultra_HD™_2D_Feature_Disc_ECB4.tgz
MrPenguin
Post by MrPenguin »
Shockmaindave wrote: Sat Dec 28, 2024 1:41 pm Strange, I have the same ECB4 code but I'm not able to decrypt it. Any suggestions? And is it awesome?
Shockmaindave
I didn't know that was something to do, but I just downloaded it, unzipped it, put it in the data directory, and even renamed it with capitals.
Why would it work for rhummer and not for me? Sorry for probably missing something obvious.
rhummer
Post by rhummer »
I didn’t download the cfg manually, I let makemkv download the data and that worked. Dunno why the two are different I thought they weren’t…
MrPenguin
Post by MrPenguin »
Shockmaindave wrote: Sun Dec 29, 2024 4:06 am I didn't know that was something to do, but I just downloaded it, unzipped it, put it in the data directory, and even renamed it with capitals.
MakeMKV will only check KEYDB if it cannot find a hashed key from its own database. Are there any messages in MakeMKV's log about failing to download anything from the network?
Shockmaindave
There had been a message about that in the past because I'd been using Cloudflare's "anti-malware" DNS.
I entered an 8.8.8.8 proxy server in the MKV preferences and that message went away.
I'm also using findVUK's sync now as you suggested.
And I'm in!!!
This reminds me--by being the complete opposite--of a time on the Plex forum, where the support I got was a suggestion "not to suck so much."
I hope I can find a way to pay back the community in kind. Thank you both.
