Dump Submitted - The Searchers - 4K_UHD
Fast Fizzy
Dump file submitted 12/25.
code DEFC
I wondered why this has not shown up anywhere.
code DEFC
keydb_helper
Re: Dump Submitted - The Searchers - 4K_UHD
The DFEC variant of The Searchers was submitted to the public keydb yesterday. I think it should work with your disc unless there are two variants with remarkably similar MakeMKV IDs.Fast Fizzy wrote: Thu Dec 26, 2024 3:47 am Dump file submitted 12/25.
code DEFC
Public KeyDB Disc Submissions
Just tried to rip my disc and it didn't open and dumped a tgz as well which I just emailed in. Not sure what's going on then.keydb_helper wrote: Thu Dec 26, 2024 4:40 amThe DFEC variant of The Searchers was submitted to the public keydb yesterday. I think it should work with your disc unless there are two variants with remarkably similar MakeMKV IDs.Fast Fizzy wrote: Thu Dec 26, 2024 3:47 am Dump file submitted 12/25.
code DEFC
keydb_helper
Are you using the public keydb? If not, you'll have to wait until MakeMKV supports your particular disc.Fresca wrote: Sat Dec 28, 2024 2:02 am Just tried to rip my disc and it didn't open and dumped a tgz as well which I just emailed in. Not sure what's going on then.
Could you post the full name of your dump file, please? There are often many different variants of each title, and we need the file name to know whether you have a variant that no-one here has seen yet.Fresca wrote: Sat Dec 28, 2024 2:02 am Just tried to rip my disc and it didn't open and dumped a tgz as well which I just emailed in. Not sure what's going on then.
MKB20_v77_The_Searchers_-_4K_UHD_DFEC.tgz is what dumped and what I emailed.MrPenguin wrote: Sat Dec 28, 2024 11:34 am Could you post the full name of your dump file, please? There are often many different variants of each title, and we need the file name to know whether you have a variant that no-one here has seen yet.
OK, so that should be the disk that KEYDB already has. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Fresca wrote: Sat Dec 28, 2024 10:18 pm MKB20_v77_The_Searchers_-_4K_UHD_DFEC.tgz is what dumped and what I emailed.
Thank you for that. I was having the same problem with same key and that worked. Do I leave the downloaded KEYDB in that folder or delete it when done?
I wasn't able to update the KEYDV.cfg file, so I'm posting here. Thanks.
AFAICT your dump file matches this existing entry in KEYDB:Elephen wrote: Mon Dec 30, 2024 7:17 pm I wasn't able to update the KEYDV.cfg file, so I'm posting here. Thanks.
0x9F43210F647B62CF4D8BBBCC48B0790FFFDDC37B = The Searchers UHD (The Searchers - 4K UHD) | D | 2024-12-25Re: Dump Submitted - The Searchers - 4K_UHD
Your suggestion worked fine. Thank you.
