Dump file submitted 12/25.
code DEFC
I wondered why this has not shown up anywhere.
Dump Submitted - The Searchers - 4K_UHD
keydb_helper
Re: Dump Submitted - The Searchers - 4K_UHD
The DFEC variant of The Searchers was submitted to the public keydb yesterday. I think it should work with your disc unless there are two variants with remarkably similar MakeMKV IDs.Fast Fizzy wrote: ↑Thu Dec 26, 2024 3:47 amDump file submitted 12/25.
code DEFC
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Just tried to rip my disc and it didn't open and dumped a tgz as well which I just emailed in. Not sure what's going on then.keydb_helper wrote: ↑Thu Dec 26, 2024 4:40 amThe DFEC variant of The Searchers was submitted to the public keydb yesterday. I think it should work with your disc unless there are two variants with remarkably similar MakeMKV IDs.Fast Fizzy wrote: ↑Thu Dec 26, 2024 3:47 amDump file submitted 12/25.
code DEFC
keydb_helper
Are you using the public keydb? If not, you'll have to wait until MakeMKV supports your particular disc.
Could you post the full name of your dump file, please? There are often many different variants of each title, and we need the file name to know whether you have a variant that no-one here has seen yet.
MKB20_v77_The_Searchers_-_4K_UHD_DFEC.tgz is what dumped and what I emailed.
OK, so that should be the disk that KEYDB already has. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
Thank you for that. I was having the same problem with same key and that worked. Do I leave the downloaded KEYDB in that folder or delete it when done?
I wasn't able to update the KEYDV.cfg file, so I'm posting here. Thanks.
AFAICT your dump file matches this existing entry in KEYDB:
0x9F43210F647B62CF4D8BBBCC48B0790FFFDDC37B = The Searchers UHD (The Searchers - 4K UHD) | D | 2024-12-25Re: Dump Submitted - The Searchers - 4K_UHD
Your suggestion worked fine. Thank you.
