Dump Submitted - The Searchers - 4K_UHD
Fast Fizzy
Post by Fast Fizzy »
Dump file submitted 12/25.
code DEFC
I wondered why this has not shown up anywhere.
keydb_helper
Re: Dump Submitted - The Searchers - 4K_UHD
Post by keydb_helper »
Fast Fizzy wrote:
Thu Dec 26, 2024 3:47 am
code DEFC
The DFEC variant of The Searchers was submitted to the public keydb yesterday. I think it should work with your disc unless there are two variants with remarkably similar MakeMKV IDs.
Fresca
Post by Fresca »
keydb_helper wrote:
Thu Dec 26, 2024 4:40 am
code DEFC
Just tried to rip my disc and it didn't open and dumped a tgz as well which I just emailed in. Not sure what's going on then.
keydb_helper
Fresca wrote:
Sat Dec 28, 2024 2:02 am
Are you using the public keydb? If not, you'll have to wait until MakeMKV supports your particular disc.
MrPenguin
Post by MrPenguin »
Could you post the full name of your dump file, please? There are often many different variants of each title, and we need the file name to know whether you have a variant that no-one here has seen yet.
Fresca
Post by Fresca »
MrPenguin wrote:
Sat Dec 28, 2024 11:34 am
MKB20_v77_The_Searchers_-_4K_UHD_DFEC.tgz is what dumped and what I emailed.
MrPenguin
Post by MrPenguin »
Fresca wrote:
Sat Dec 28, 2024 10:18 pm
OK, so that should be the disk that KEYDB already has. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
wocket
Post by wocket »
MrPenguin wrote:
Sat Dec 28, 2024 10:23 pm
Thank you for that. I was having the same problem with same key and that worked. Do I leave the downloaded KEYDB in that folder or delete it when done?
Elephen
Post by Elephen »
I wasn't able to update the KEYDV.cfg file, so I'm posting here. Thanks.
MrPenguin
Post by MrPenguin »
Elephen wrote:
Mon Dec 30, 2024 7:17 pm
AFAICT your dump file matches this existing entry in KEYDB:
0x9F43210F647B62CF4D8BBBCC48B0790FFFDDC37B = The Searchers UHD (The Searchers - 4K UHD) | D | 2024-12-25
So if you copy the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV then you should be able to decrypt your disk.
Elephen
Post by Elephen »
Your suggestion worked fine. Thank you.
