That will NOT help the users here who can't solder chips.GriffinJax wrote: Tue Oct 22, 2024 10:25 pmThank you Very much.Billycar11 wrote: Tue Oct 22, 2024 10:16 pm i dont but there was not much of interest up there
it was an s13UBK
it gives me a place to start so I can dig through data sheets until a drive gets here.
Re: Pioneer firmware update February 2023
Todd_2003
Thank you for replying. I'm hopeful there is a fix at some point. By the time I posted initially, I was past the Amazon return window, so I'm stuck with the drive.Billycar11 wrote: Fri Jul 26, 2024 12:51 amNah sorry man if you can return it.Todd_2003 wrote: Fri Jul 26, 2024 12:36 am Hello. I'm having the same issue with a too current Firmeware version on the Pionner BDR-S13U-X, I have Revision 1.04 from 12-12-2022. I bought the drive from Amazon a few months ago because it was the "best" according to many reviews, but now I'm seeing the huge limitation with UHD 4k movies. Any fix in sight yet? Thank you!
I have those with old fw if you want one.
See below
bodivijay1985
Dear Experts,
Anyway to enable Libredrive for the following drive,
OS device name: F:
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-XS08U
Revision: 1.00
Serial number: BLDLXXXXXXJP
Firmware date: 2022-10-11
Highest AACS version: 61
Drive platform: Pioneer RS9621
Firmware version: ID69
Disc Information
Data capacity: 0.0 Gb
Disc type: BD-R
Number of layers: 2
Thank you,
Bodivijay
OS device name: F:
Revision: 1.00
Disc Information
Disc type: BD-R
Number of layers: 2
Thank you,
Bodivijay
MrPenguin
Ooo, exciting...bodivijay1985 wrote: Tue Dec 10, 2024 8:09 pm Anyway to enable Libredrive for the following drive,
Revision: 1.00
Please Do Not Update This Drive's Firmware!
In practice, you're almost certainly going to need to ask Mike to proceed with enabling LibreDrive.
bodivijay1985
Hi MrPenguin,
Thank you. I will not update the drive firmware
Bodivijay1985
Bodivijay1985
bodivijay1985
Dear Mike admin,
Please help me to enable LibreDrive in the following drive,
OS device name: F:
Revision: 1.00
Thank you,
Bodivijay1985
OS device name: F:
Revision: 1.00
Thank you,
Bodivijay1985
KiwiUK
Hello, I bought and received from Amazon.au a Pioneer BDR-212D, manufactured in June 2024 according to the label but using makeMKV I see this and hope I have struck it lucky?
Can someonce advise me either way and if all good what do I do next? I have a few 4k movies coming for Christmas
OS device name: F:
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: DGDL********
Firmware date: 2022-03-16
Bus encryption flags: 13
Drive platform: RS8F00
Firmware version: 1.02/ID61
OS device name: F:
Revision: 1.02
PM is coming.KiwiUK wrote: Tue Dec 24, 2024 3:33 am Hello, I bought and received from Amazon.au a Pioneer BDR-212D, manufactured in June 2024 according to the label but using makeMKV I see this and hope I have struck it lucky?Can someonce advise me either way and if all good what do I do next? I have a few 4k movies coming for Christmas
OS device name: F:
Revision: 1.02
KiwiUK
Thank you so much, works perfectly
HurricaneHarvey
I received a Pioneer external BD drive for xmas however I understand it can not currently be flashed with libredrive as the firmware is 1.03 and at 22-12-12. Is the Pioneer firmware issue still actively being worked on at this time or has it fallen off the radar?
OS device name: F:
Product: BD-RW BDR-X13U
Revision: 1.03
Serial number: CGDL300295UC
Firmware date: 2022-12-12
Highest AACS version: 77
OS device name: F:
Revision: 1.03
Fw is to new sorry return it if you can and get a pioneer from me Marty or asmcom if you want one with old fwHurricaneHarvey wrote: Wed Dec 25, 2024 8:48 pm I received a Pioneer external BD drive for xmas however I understand it can not currently be flashed with libredrive as the firmware is 1.03 and at 22-12-12. Is the Pioneer firmware issue still actively being worked on at this time or has it fallen off the radar?
OS device name: F:
Revision: 1.03
Jerry_678
I just got a Pioneer BDR-212V drive from Amazon and from what I'm reading it looks like the firmware is old enough to still flash. If so, can I get the instructions for updating the drive to LibreDrive Support?
Product: BD-RW BDR-212V
Revision: 1.02
Firmware date: 2022-05-31
Highest AACS version: 68
Firmware version: ID06
Revision: 1.02
Yeah email me see belowJerry_678 wrote: Sun Dec 29, 2024 7:51 pm I just got a Pioneer BDR-212V drive from Amazon and from what I'm reading it looks like the firmware is old enough to still flash. If so, can I get the instructions for updating the drive to LibreDrive Support?
Revision: 1.02
dot_1829
Hi everyone!
I received a Verbatim slim drive for christmas and I'm trying to understand how to use it properly with makemkv
It says that Libredrive is enabled, but disks won't read?
Here are the details. Any help would be appreciated!
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Revision: 1.14
Serial number:
Most likely a power problem since the enclosure is very power hungry. Connect o USB-C if possible or to a powered USB hub.dot_1829 wrote: Mon Dec 30, 2024 1:35 pm Hi everyone!
Revision: 1.14
Serial number:
