Dump file sent
Hi - sharing a dump file for Reign of the Supermen
https://www.mediafire.com/file/ds971hop ... 3.tgz/file
Re: Reign of the Supermen
Thanks for the link, but this dump looks suspiciously small to me...
jarrod2750
Sent these via PM too. Sorry for the extra work and thank you
CORRECTED LINKS
https://www.mediafire.com/file/9bsi6gpl ... 3.zip/file
Corrected MKB Link
https://www.mediafire.com/file/c0w9c3lw ... O.zip/file
CORRECTED LINKS
Corrected MKB Link
keydb_helper
Thanks for the dump files and corrected MKB file. The 7AA3 variant of Reign of the Supermen has been added to the public keydbjarrod2750 wrote: ↑Fri Dec 13, 2024 2:21 pmSent these via PM too. Sorry for the extra work and thank you
CORRECTED LINKS
Corrected MKB Link
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
tarnish778
I'm getting the The volume key is unknown for this disc - video can't be decrypted error for this disk even though I have the 7AA3 version as well. How can I double check my hash db is up to date? maybe that's the issue?
It sounds like this disk hasn't been added to MakeMKV's hashed keys yet, although it is already present in the latest KEYDB.cfg file. So download this file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.tarnish778 wrote: ↑Sat Dec 21, 2024 12:53 amI'm getting the The volume key is unknown for this disc - video can't be decrypted error for this disk even though I have the 7AA3 version as well. How can I double check my hash db is up to date? maybe that's the issue?
