Immaculate-4K UHD Dump Submitted
MSCloude115
Post by MSCloude115 »
I have submitted the Immaculate 4K dump by email. The file name is MKB20_v77_Immaculate_9066
JinjoSnap
Re: Immaculate-4K UHD Dump Submitted
Post by JinjoSnap »
Also submitted this dump, using LG WH16NS60 drive with 1.03 firmware.
Google drive link as well: https://drive.google.com/file/d/1m1pFQX ... sp=sharing
JinjoSnap
Post by JinjoSnap »
Also just wanted to say that after manually updating to the latest keydb.cfg, I could rip the disc.
MSCloude115
JinjoSnap wrote: Fri Dec 20, 2024 6:35 am Also just wanted to say that after manually updating to the latest keydb.cfg, I could rip the disc.
I have tried many times to use keydb and for some strange reason it will not work for me so it looks like i'll be waiting for the keys to be added :(
Post by SamuriHL »
Can you describe in detail exactly what steps you're taking to use the keydb?
Sent from my SM-S928U1 using Tapatalk
MSCloude115
SamuriHL wrote: Sun Dec 22, 2024 5:08 am Can you describe in detail exactly what steps you're taking to use the keydb?
I’ve actually tried two different methods from what I’ve read. My father who also is a member did the first through offsite access. He uses a Mac and he placed the keydb file on my desktop which didn’t work as it was requesting access to dvdfab which I do not have or intend to pay for. The other, I downloaded the keydb file and extracted then placed in my makemkv file on my computer. I restarted makemkv then tried repeatedly without success.
Post by SamuriHL »
No that's not correct. It has to be extracted to a very specific folder. It can't just be put anywhere. The folder that the tgz dump files are created when makemkv doesn't have a hashed key for a title is where the KEYDB.cfg file needs to go. And on a Mac, the case might matter. So rename it to what I just wrote.
keydb_helper
Post by keydb_helper »
MSCloude115 wrote: Sun Dec 22, 2024 12:51 pm I’ve actually tried two different methods from what I’ve read. My father who also is a member did the first through offsite access. He uses a Mac and he placed the keydb file on my desktop which didn’t work as it was requesting access to dvdfab which I do not have or intend to pay for.
Just to clarify, the keydb doesn't request access to dvdfab or any other 3rd party utility. The keydb as recommended in this thread is literally just a very large plain text file.
I think you may have mixed it up with the FindVUK utility which is a means for making submissions to the keydb but is in no way a prerequisite for using the keydb.
MSCloude115 wrote: Sun Dec 22, 2024 12:51 pm The other, I downloaded the keydb file and extracted then placed in my makemkv file on my computer. I restarted makemkv then tried repeatedly without success.
Not every disc is supported by the keydb but dozens of discs are added every day. The user JinjoSnap has indicated that your particular disc is supported, so it seems that you have a configuration issue. This is normally caused by one of the following:
  • Failing to unzip the downloaded keydb_eng.zip file
  • Downloading an ancient keydb.cfg file from a random mirror which doesn't include any UHD keys
  • Placing the extracted keydb.cfg file in the incorrect directory
I've written up a brief guide to configure the public keydb here. Please let me know if any aspect is unclear. But essentially if you can download a zip file, extract it, and copy the resultant file to the correct folder you'll be able to process your disc right away. Otherwise you may have to wait several more days or weeks for MakeMKV to support your title.
Public KeyDB Disc Submissions
MSCloude115
keydb_helper wrote: Sun Dec 22, 2024 1:32 pm
Thanks so much! I’m not sure what I did that was different but I followed your instructions to a T and it started working. I appreciate your help and have a wonderful day!
keydb_helper
MSCloude115 wrote: Sun Dec 22, 2024 1:52 pm Thanks so much! I’m not sure what I did that was different but I followed your instructions to a T and it started working. I appreciate your help and have a wonderful day!
Glad to hear you got it working. Don't forget to update your local keydb.cfg file if you find another unsupported title.
MSCloude115
keydb_helper wrote: Sun Dec 22, 2024 2:16 pm
How would I go about updating the file? Just download it again and replace?
Post by SamuriHL »
Yup
MrPenguin
Post by MrPenguin »
MSCloude115 wrote: Sun Dec 22, 2024 2:40 pm How would I go about updating the file? Just download it again and replace?
Ideally, you could download FindVUK.exe and then execute
findvuk synchronize
to refresh a local copy of KEYDB.cfg. This would save you from downloading a large ZIP file each time.
MSCloude115
MrPenguin wrote: Sun Dec 22, 2024 2:54 pm
findvuk synchronize
Great! Thanks again:)
