Dump Submit The Tai-Chi Master
james gilicuty
Post by james gilicuty »
MKB20_v77_TAI_CHI_MASTER_63C0
The Tai-Chi Master 4k
‎October 11, 2024
‎ 88 Films
james gilicuty
Re: Dump Submit The Tai-Chi Master
what's the hold up? I submitted this about a week ago and it still wont rip.
MrPenguin
Post by MrPenguin »
james gilicuty wrote:
Thu Dec 19, 2024 2:15 pm
The amount of time it takes for svq@makemkv.com to generate a new hashed key has always been both unknown and unknowable. Have you tried using the alternative KEYDB key database? Basically, you need to download the KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restart MakeMKV.
