I have just submitted MKB20_v77_Dune-_Part_Two_95C0.tgz. As I have seen, this version has
not been submitted.
Dune Part 2 Dump Submitted
MrPenguin
Re: Dune Part 2 Dump Submitted
EricLille
Hello
I’m in France and i bought Dune 2 in uhd disc. I tried to rip it and makemkv doesn’t succeed to open the disc.
I sent the tgz file to svq@makemkv.com. it still doesn’t work
I updated the keydb. It doesn’t work. Where should i place this file in the makemkv directory ?
Thanks for your advices
MrPenguin
Copy the latest KEYDB.cfg file into the same directory where MakeMKV writes its .tgz dump files, and then restart MakeMKV. If you're using MacOS or Linux then you should also ensure that the file name is KEYDB.cfg and not keydb.cfg, because the file-system is case-sensitive.EricLille wrote: Wed Jul 10, 2024 6:42 pm Hello
What is the full name of your tgz dump file please?
Fu2chN
Hi, same problem as EricLille.
"MKB20_v77_Dune-_Part_Two_95C0.tgz"
EricLille
Yes it’s the same tgz name as Fu2chN
EricLille
I copied the keydb.cfg in the tgz files directory. It doesn’t workMrPenguin wrote: Wed Jul 10, 2024 7:00 pmCopy the latest KEYDB.cfg file into the same directory where MakeMKV writes its .tgz dump files, and then restart MakeMKV. If you're using MacOS or Linux then you should also ensure that the file name is KEYDB.cfg and not keydb.cfg, because the file-system is case-sensitive.EricLille wrote: Wed Jul 10, 2024 6:42 pm Hello
Are there other solutions ?
MrPenguin
"Waiting for Mike" is the obvious solution, although it's also worth checking the KEYDB.cfg file periodically while you wait. The KEYDB.cfg file is constantly updated by people across the Internet, and so you might be lucky with a newer title because someone else could reasonably add your disk while you're waiting.EricLille wrote: Thu Jul 11, 2024 4:57 am I copied the keydb.cfg in the tgz files directory. It doesn’t work
EricLille
I already had the same problem with other uhd discs. i asked my retailer to change the disc and this new one worked immediately with makemkv. How do you explain that ?
MrPenguin
There are two possible explanations:EricLille wrote: Thu Jul 11, 2024 7:04 pm I already had the same problem with other uhd discs. i asked my retailer to change the disc and this new one worked immediately with makemkv. How do you explain that ?
- Mike had computed the key for your disk while you were busy exchanging it.
- Your new disk has a different "master disk" to your original disk, and MakeMKV already knew your new disk's key.
Rocket
Thank you for your suggestion! For the moment I have time, so I'll wait a few days. But it's good to know this workaround.MrPenguin wrote: Tue Jul 09, 2024 10:01 amHave you tried installing the latest KEYDB.cfg file into your .MakeMKV directory (which is where MakeMKV wrote your .tgz dump file)?Rocket wrote: Tue Jul 09, 2024 9:53 am I have just submitted MKB20_v77_Dune-_Part_Two_95C0.tgz. As I have seen, this version has
not been submitted.
EricLille
I have updated the keydb this morning and it worked.
Thank you !
Thank you !
MrPenguin
Thanks for confirming that KEYDB.cfg now contains a key for the 95C0 variant.
EricLille
6th sense uhd disc - issue to open the disc
Hi, i sent you a mail about the sixth sense uhd bluray that the sofware can't open. Could you take a look to my problem ?
Eric
Eric
MrPenguin
Re: 6th sense uhd disc - issue to open the disc
This thread is about "Dune: Part 2". Wouldn't this thread be a better place to ask?EricLille wrote: Thu Dec 19, 2024 9:28 am Hi, i sent you a mail about the sixth sense uhd bluray that the sofware can't open. Could you take a look to my problem ?
