Transformers One - Dump Submitted
Greetings,
MKB20_v77_Transformers_One_032E
I will also upload to Google Drive.
bluebanshee76
Re: Transformers One - Dump Submitted
MKB20_v77_TRANSFORMERS_ONE_0080 submitted
Greetings,Ralph P. wrote: Sun Dec 08, 2024 6:34 pm Greetings,
I can confirm that this configuration now works. Thank you!
dawg_ripper
my disk is MKB20_v77_TRANSFORMERS_ONE_032E as well and it didnt work for me yet. yes it downloaded the latest HK.
My delivery is 10 stops away, so thanks in advance for the submissions!
Also submitted 032E.
Submitted 032E yesterday as well (16-Dec)
Your variant corresponds to this KEYDB entry:
0x0371A62C3DE7157722FCD22CADEB8141BAE1FF24 = TRANSFORMERS_ONE (Transformers One) | D | 2024-10-09Re: Transformers One - Dump Submitted
I did as you mentioned and it worked perfectly, so huge thanks!MrPenguin wrote: Wed Dec 18, 2024 1:35 amYour variant corresponds to this KEYDB entry:Try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV.Code: Select all
In the past I have received discs on release day and the keys weren't available at that point in time, so I typically just wait it out as I see others had already submitted their AACS dumps, for the same release/region.
Am I safe to assume, had I waited until tomorrow to backup my disc, the key for it would have been automatically downloaded via MakeMKV?
(Mainly just curious if it is purely down to me being impatient with this particular title and time window)
This worked great for me also, thanks so much!MrPenguin wrote: Wed Dec 18, 2024 1:35 amYour variant corresponds to this KEYDB entry:Try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV.Code: Select all
keydb_helper
The delay for recent titles to be natively supported by MakeMKV is anywhere from several days to several weeks.mutelight wrote: Wed Dec 18, 2024 2:16 am In the past I have received discs on release day and the keys weren't available at that point in time, so I typically just wait it out as I see others had already submitted their AACS dumps, for the same release/region.
If you'd like to help add title support to the public keydb, feel free to include links to disc dumps in your forum posts. Please note that disc dumps produced by LG/Asus drives are more useful at this point in time.
Public KeyDB Disc Submissions
Worked perfectly. Thank you!MrPenguin wrote: Wed Dec 18, 2024 1:35 amYour variant corresponds to this KEYDB entry:Try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV.Code: Select all
Dump submitted for the Aussie UHD disc.
MKB20_v77_TRANSFORMERS_ONE_8140
MSCloude115
I have also submitted my dump file for Transformers One UHD. The file name is MKB20_v77_Transformers_One_032E
I too can confirm this worked great! Thank you!MrPenguin wrote: Wed Dec 18, 2024 1:35 amYour variant corresponds to this KEYDB entry:Try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV.Code: Select all
