Reign of the Supermen
jarrod2750
#1 Post by jarrod2750 » Fri Dec 13, 2024 12:53 pm
Dump file sent
Hi - sharing a dump file for Reign of the Supermen
https://www.mediafire.com/file/ds971hop ... 3.tgz/file
MrPenguin
Re: Reign of the Supermen
#2 Post by MrPenguin » Fri Dec 13, 2024 1:08 pm
Thanks for the link, but this dump looks suspiciously small to me... :?
jarrod2750
#3 Post by jarrod2750 » Fri Dec 13, 2024 2:21 pm
Sent these via PM too. Sorry for the extra work and thank you
CORRECTED LINKS
https://www.mediafire.com/file/9bsi6gpl ... 3.zip/file
Corrected MKB Link
https://www.mediafire.com/file/c0w9c3lw ... O.zip/file
keydb_helper
#4 Post by keydb_helper » Sat Dec 14, 2024 2:13 am
CORRECTED LINKS
Corrected MKB Link
Thanks for the dump files and corrected MKB file. The 7AA3 variant of Reign of the Supermen has been added to the public keydb
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
jarrod2750
#5 Post by jarrod2750 » Sat Dec 14, 2024 11:13 pm
Thank you
tarnish778
#6 Post by tarnish778 » Sat Dec 21, 2024 12:53 am
I'm getting the The volume key is unknown for this disc - video can't be decrypted error for this disk even though I have the 7AA3 version as well. How can I double check my hash db is up to date? maybe that's the issue?
MrPenguin
#7 Post by MrPenguin » Sat Dec 21, 2024 11:45 am
It sounds like this disk hasn't been added to MakeMKV's hashed keys yet, although it is already present in the latest KEYDB.cfg file. So download this file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
