Dump Submitted - Deep Impact 4k German
ellap
Post by ellap »
Could you please add the disc to the public keydb?
Re: Dump Submitted - Deep Impact 4k German
Did you submit this file to svq@makemkv.com via email as well, so it can be added to MakeMKV's database?
keydb_helper
Post by keydb_helper »
ellap wrote:
Thu Dec 12, 2024 8:30 am
I'm not sure if the issue is on my end but your disc dump seems to be a corrupt 32KB file. It should be 2-8MB. Could you please regenerate the dump file and re-attach it?
Public KeyDB Disc Submissions
  • LG/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
MrPenguin
Post by MrPenguin »
keydb_helper wrote:
Thu Dec 12, 2024 3:06 pm
The forum server definitely says that the file is only 32KiB.
ellap
Post by ellap »
Sorry, here is the new file.
MrPenguin
Post by MrPenguin »
ellap wrote:
Thu Dec 12, 2024 4:18 pm
ellap
Post by ellap »
MrPenguin wrote:
Thu Dec 12, 2024 8:31 pm
Now it works. Thanks a lot for your help!
