Dump Submitted - Deep Impact 4k German
ellap
Could you please add the disc to the public keydb?
Re: Dump Submitted - Deep Impact 4k German
Did you submit this file to svq@makemkv.com via email as well, so it can be added to MakeMKV's database?
keydb_helper
I'm not sure if the issue is on my end but your disc dump seems to be a corrupt 32KB file. It should be 2-8MB. Could you please regenerate the dump file and re-attach it?
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
MrPenguin
The forum server definitely says that the file is only 32KiB.keydb_helper wrote: Thu Dec 12, 2024 3:06 pm I'm not sure if the issue is on my end but your disc dump seems to be a corrupt 32KB file. It should be 2-8MB.
ellap
Sorry, here is the new file.
MrPenguin
ellap
Now it works. Thanks a lot for your help!
