Halo S2 (Australia) - 4 discs
Dumps for 3 discs (one to come):
Re: Halo S2 (Australia) - 4 discs
I will leave your attachments long enough for keydb_helper to download them for the alternative decode people, but they will be deleted after that. You DID submit them to svq@makemkv.com so they can be added to MakeMKV, correct?
All three of your attached dumps have been added to the public keydb. Feel free to ping me when you are ready with the disc 1 dump.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Thank you!keydb_helper wrote: ↑Wed Dec 11, 2024 9:43 pmAll three of your attached dumps have been added to the public keydb. Feel free to ping me when you are ready with the disc 1 dump.
No problem. I'm submitting Halo S2D1 to the public keydb now.
