Halo S2 (Australia) - 4 discs
JasonACT
Post by JasonACT »
Dumps for 3 discs (one to come):
Re: Halo S2 (Australia) - 4 discs
I will leave your attachments long enough for keydb_helper to download them for the alternative decode people, but they will be deleted after that. You DID submit them to svq@makemkv.com so they can be added to MakeMKV, correct?
MrPenguin
Post by MrPenguin »
JasonACT wrote:
Wed Dec 11, 2024 9:31 am
keydb_helper
Post by keydb_helper »
All three of your attached dumps have been added to the public keydb. Feel free to ping me when you are ready with the disc 1 dump.
Public KeyDB Disc Submissions
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
JasonACT
Post by JasonACT »
keydb_helper wrote:
Wed Dec 11, 2024 9:43 pm
Thank you!
keydb_helper
JasonACT wrote:
Thu Dec 12, 2024 5:02 am
Thank you!
No problem. I'm submitting Halo S2D1 to the public keydb now.
