Submitted dump files for The Dark Knight Trilogy of movies in 4K
MKB20_v61_Batman_Begins_440F
MKB20_v68_The_Dark_Knight_6591
MKB20_v61_Dark_Knight_Rises_8BC3
These were originally submitted on 11/24 and I'm still getting a key failure when I try to open it. Is there just a delay in processing or is there something else wrong here?
Dumps Submitted - Dark Knight Trilogy 4k
Re: Dumps Submitted - Dark Knight Trilogy 4k
Sometimes it takes a while.
You're not getting any download failed errors in your log are you?
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Millertime wrote: Tue Dec 10, 2024 7:42 pm MKB20_v61_Batman_Begins_440F
This public database may already contain the keys you need...
Millertime
No just the "key not found" error.dcoke22 wrote: Tue Dec 10, 2024 8:20 pm Sometimes it takes a while.
I have the latest Keydb downloaded, so no fix there either
FhiiZo
I send my dump but he don’t work
Mintakax
I was able to rip all three UHDs. I do have the latest key file.
