Dumps Submitted - Dark Knight Trilogy 4k
Millertime
Post by Millertime »
Submitted dump files for The Dark Knight Trilogy of movies in 4K
MKB20_v61_Batman_Begins_440F
MKB20_v68_The_Dark_Knight_6591
MKB20_v61_Dark_Knight_Rises_8BC3
These were originally submitted on 11/24 and I'm still getting a key failure when I try to open it. Is there just a delay in processing or is there something else wrong here?
Re: Dumps Submitted - Dark Knight Trilogy 4k
Sometimes it takes a while.
You're not getting any download failed errors in your log are you?
MrPenguin
Post by MrPenguin »
Millertime wrote: Tue Dec 10, 2024 7:42 pm MKB20_v61_Batman_Begins_440F
This public database may already contain the keys you need...
Millertime
dcoke22 wrote: Tue Dec 10, 2024 8:20 pm Sometimes it takes a while.
No just the "key not found" error.
I have the latest Keydb downloaded, so no fix there either
FhiiZo
Post by FhiiZo »
I send my dump but he don’t work
Mintakax
Post by Mintakax »
I was able to rip all three UHDs. I do have the latest key file.
