Paris, Texas (Curzon) dump submitted
cinemaniac93
MKB20_v77_PARIS_TEXAS_053E.tgz
keydb_helper
Re: Paris, Texas (Curzon) dump submitted
The 053E variant of Paris, Texas has been added to the public keydb
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
cinemaniac93
Thanks for the notification!keydb_helper wrote: Mon Dec 09, 2024 11:51 amThe 053E variant of Paris, Texas has been added to the public keydb
simland
I just got this today but sadly doesn't open. I was going to submit the file when I saw the post above, it's the same file.
My logs look like this:
Any suggestions appreciated.
The odd thing is I don't see a message about 'Downloading the latest HK' that others have shown. I'm using the flatpak on Linux which always been fine, so far.MakeMKV v1.17.8 linux(x64-release) started
Debug logging enabled, log will be saved as /var/home/sim/MakeMKV_log.txt
Using LibreDrive mode (v01.0 id=27184B96DBEE)
Saved AACS dump file as /var/home/sim/.MakeMKV/MKB20_v77_PARIS_TEXAS_053E.tgz
DEBUG: Code 0 at >THe}IL`%#jvsJ!t:213132721
DEBUG: Code 0 at >THe}IL`%#jvsJ!t:213131341
MrPenguin
Either install the latest public KEYDB.cfg file, or wait for MakeMKV to generate a new hashed key for your disk
