MKB20_v61_Underworld-_Blood_Wars_E4B9
Disc Information
Label: UNDERWORLD_BLOOD_WARS
Timestamp: 2017-02-06 21:49:32
Protection: AACS2.0/C v61
Data capacity: 4498.84 Gb
Bus encryption flags: 80
Debug log started at Tue Dec 10 16:20:56 2024 , written by MakeMKV v1.17.8 win(x64-release)
001005:0000 MakeMKV v1.17.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\XXX/MakeMKV_log.txt
DEBUG: Code 3 at E}P)4^&Zt'eI2]i`NTMR>^^t:29395310
SDF v098: PIONEER_BD-RW__BDR-XS07U_1.02_CGDL007525WL
001011:0000 Using LibreDrive mode (v01.0 id=CA5C627C459A)
DEBUG: Code 2147483648 at VtT$hoa+N}'B:VS3:121265499
003332:0000 Saved AACS dump file as file://C:\Users\XXX/.MakeMKV/MKB20_v61_Underworld-_Blood_Wars_E4B9.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
001003:0020 DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
Dump Submitted - Underworld - Blood Wars (2016)
MrPenguin
Re: Dump Submitted - Underworld - Blood Wars (2016)
The latest KEYDB.cfg file contains several entries for this title. Does downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?ChrDk wrote: Tue Dec 10, 2024 4:27 pm MKB20_v61_Underworld-_Blood_Wars_E4B9
ChrDk
I tried downloading almost all the KEYDB from fvonlinedb (even though they state it contains the same), and restarted MakeMKV for each file, because that has done the trick earlier for a few of the discs that initially reported the same. But to no avail.MrPenguin wrote: Tue Dec 10, 2024 4:42 pmThe latest KEYDB.cfg file contains several entries for this title. Does downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?ChrDk wrote: Tue Dec 10, 2024 4:27 pm MKB20_v61_Underworld-_Blood_Wars_E4B9
ChrDk
It works now, and MrPenguin was nice enough to help with figuring out that the key is present in the KEYDB. Still a mystery to me why the disc couldn't be read after trying the various KEYDB files from FindVUK, and restarting MakeMkv. Does the actual eject of a disc, and reinserting it helps?
MrPenguin
For some drives, ejecting and reinserting the disk isn't enough to reset LibreDrive. E.g. you would need to power-cycle a Pioneer drive for a complete reset.ChrDk wrote: Wed Dec 11, 2024 6:43 am It works now, and MrPenguin was nice enough to help with figuring out that the key is present in the KEYDB. Still a mystery to me why the disc couldn't be read after trying the various KEYDB files from FindVUK, and restarting MakeMkv. Does the actual eject of a disc, and reinserting it helps?
