Greetings,
MKB20_v77_Galaxy_Quest_D770
I submitted this and will follow up with uploading to Google Drive for KeyDB.
Regards,
Galaxy Quest Dump Submitted
Re: Galaxy Quest Dump Submitted
Greetings,
This title is now part of KEYdb. I was able to successfully rip it via Makemkv. Thank you!
I'm guessing MakeMKV must have computed its hashed key, because the only UHD entry in KEYDB for "Galaxy Quest" contains a unit key but no VUK.
rogueranger89
I Submitted another Dump File for Galaxy Quest that has a different Code at the end.
MKB20_v77_Galaxy_Quest_E536.tgz
OneDrive Link for the files: https://1drv.ms/f/c/6191de0a61c46047/Em ... A?e=hewqsD
keydb_helper
Thanks for the disc dump. The E536 variant of Galaxy Quest has been added to the public keydbrogueranger89 wrote: ↑Thu Nov 28, 2024 6:37 pmI Submitted another Dump File for Galaxy Quest that has a different Code at the end.
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
In a separate thread, Flavour found and submitted a third variant: MKB20_v77_Galaxy_Quest_60AC
agentbrowder
I've submitted another dump for Galaxy Quest for Australia:
MKB20_v77_Galaxy_Quest_631E
Also attached for keyed_helper.
keydb_helper
Thanks for the disc dump. Your disc has been added to the public keydb.agentbrowder wrote: ↑Wed Jan 15, 2025 6:08 amI've submitted another dump for Galaxy Quest for Australia:
You were fortunate that the existing media key for Galaxy Quest matched your disc variant. Please remember that Pioneer disc dumps are generally less useful compared to LG/Asus dumps.
