Dump Submitted Beetlejuice Beetlejuice 4K
MKB20_v77_Beetlejuice_Beetlejuice_6EB6.tgz
Got it from GRUV today.
keydb_helper
Re: Dump Submitted Beetlejuice Beetlejuice 4K
The 6EB6 release of Beetlejuice Beetlejuice has been added to the public keydb. It should support your disctheprower wrote: Thu Nov 14, 2024 1:22 am MKB20_v77_Beetlejuice_Beetlejuice_6EB6.tgz
Public KeyDB Disc Submissions
That worked. Thanks.keydb_helper wrote: Thu Nov 14, 2024 2:19 amThe 6EB6 release of Beetlejuice Beetlejuice has been added to the public keydb. It should support your disctheprower wrote: Thu Nov 14, 2024 1:22 am MKB20_v77_Beetlejuice_Beetlejuice_6EB6.tgz
CalicoSkies
Is there a way to have MakeMKV force an update of the keydb? I got my copy of Beetlejuice Beetlejuice today too, but makemkv isn't recognizing it for me.
The recommended way to update KEYDB is to use "findvuk synchronize", where findvuk.exe is a Windows executable that also runs on wineconsole. And then copy the new KEYDB.cfg file into MakeMKV's data directory, of course.CalicoSkies wrote: Fri Nov 15, 2024 2:53 am Is there a way to have MakeMKV force an update of the keydb? I got my copy of Beetlejuice Beetlejuice today too, but makemkv isn't recognizing it for me.
CalicoSkies
Thanks.MrPenguin wrote: Fri Nov 15, 2024 10:58 amThe recommended way to update KEYDB is to use "findvuk synchronize", where findvuk.exe is a Windows executable that also runs on wineconsole. And then copy the new KEYDB.cfg file into MakeMKV's data directory, of course.CalicoSkies wrote: Fri Nov 15, 2024 2:53 am Is there a way to have MakeMKV force an update of the keydb? I got my copy of Beetlejuice Beetlejuice today too, but makemkv isn't recognizing it for me.
Ballesteros
MKB20_v77_Beetlejuice_Beetlejuice_EE80.tgzNot working for me with the latest keydb from FindVUK either.
Ballesteros
The "_EE80" disc is decrypting for me as of today.
