HORIZON Dump Submitted German 4K UHD
Rodney M
Post by Rodney M » Thu Nov 28, 2024 5:14 pm
Greetings,
MKB20_v77_HORIZON_UHD_EF26.tgz
Submitted.
Regards,
Rodney M
Re: HORIZON Dump Submitted German 4K UHD
Post by Rodney M » Sun Dec 01, 2024 1:14 pm
Unfortunately it doesn't work yet, did the dump not arrive?
Should I send it again?
best regards
keydb_helper
Post by keydb_helper » Sun Dec 01, 2024 11:24 pm
Rodney M wrote: Thu Nov 28, 2024 5:14 pm Greetings,
Submitted.
Regards,
The EF26 variant of Horizon has been added to the public keydb
Public KeyDB Disc Submissions
Rodney M
Post by Rodney M » Tue Dec 03, 2024 1:44 pm
doesn't work :(
keydb_helper
Post by keydb_helper » Tue Dec 03, 2024 2:10 pm
Rodney M wrote: Tue Dec 03, 2024 1:44 pm doesn't work :(
Hey Rodney, just to be clear, have you downloaded and setup the alternative/public key database file? I ask because the keys for your EF26 disc were added a few days ago.
The ‘keydb’ I referred to is an alternative source of disc keys, distinct from the native MakeMKV keys. If you have downloaded the latest keydb and your disc still isn’t working feel free to PM me.
Rodney M
Post by Rodney M » Tue Dec 03, 2024 3:13 pm
Thank you very much for the quick info, I have never used the alternative/public key database file!
Do you have a link for me and how do I embed it in MKV?
Sorry for the beginner questions.
MrPenguin
Post by MrPenguin » Tue Dec 03, 2024 3:18 pm
Rodney M wrote: Tue Dec 03, 2024 3:13 pm Do you have a link for me and how do I embed it in MKV?
Download this ZIP file, unpack the KEYDB.cfg file inside it, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restart MakeMKV.
You will need to update your KEYDB.cfg file periodically. The FindVUK.exe tool can do this:
findvuk synchronize
Rodney M
Post by Rodney M » Tue Dec 03, 2024 3:40 pm
Thanks so much :D
