Dump Submitted - Godzilla Minus One UHD (AllTheAnime FR edition)
matheousse
Post by matheousse » Wed Nov 27, 2024 2:07 pm
MKB20_v77_GODZILLA_MINUS_ONE_343A.tgz submitted to svq@makemkv.com
The disc (from the FR Steelbook) is most likely the same as the UK and ITA Steelbooks/Deluxe Editions releasing in a few days.
MrPenguin
Re: Dump Submitted - Godzilla Minus One UHD (AllTheAnime FR edition)
Post by MrPenguin » Wed Nov 27, 2024 3:18 pm
matheousse wrote: Wed Nov 27, 2024 2:07 pm MKB20_v77_GODZILLA_MINUS_ONE_343A.tgz submitted to svq@makemkv.com
Have you tried downloading the latest KEYDB.cfg file, coping it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
matheousse
Post by matheousse » Wed Nov 27, 2024 4:52 pm
I just downloaded the English (26485 entries) keydb.cfg and put it in C:\Users\XXX\.MakeMKV, unfortunately MakeMKV still couldn't dump it. (also tried the French file for good mesure, no bueno)
VikingSven
Post by VikingSven » Fri Nov 29, 2024 12:27 pm
Can confirm the UK Steelbook is the same 343A version
keydb_helper
Post by keydb_helper » Mon Dec 02, 2024 12:01 pm
The 343A variant of Godzilla Minus One has been added to the public keydb. It should work for your disc.
Public KeyDB Disc Submissions
matheousse
Post by matheousse » Mon Dec 02, 2024 2:36 pm
keydb_helper wrote: Mon Dec 02, 2024 12:01 pm The 343A variant of Godzilla Minus One has been added to the public keydb. It should work for your disc.
I can see the new UHD disc in the newest keydb.cfg files (at line 58177 or thereabout), however I am still getting the The volume key is unknown for this disc - video can't be decrypted error after dragging the extracted content to C:\Users\XXX\.MakeMKV folder. Am I perhaps doing something wrong? I am also noticing that MakeMKV is downloading a new _private_data.tar archive on each attempt.
For reference, here the info about my drive (I've already ripped several UHDs in the past, so I don't think something is wrong on the hardware side):
OS device name: I:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.11
Serial number: X
Firmware date: 2119-02-27 13:19
Bus encryption flags: 1E
Highest AACS version: 77
Firmware version: 3.11
MrPenguin
Post by MrPenguin » Mon Dec 02, 2024 2:43 pm
matheousse wrote: Mon Dec 02, 2024 2:36 pm I can see the new UHD disc in the newest keydb.cfg files (at line 58177 or thereabout), however I am still getting the The volume key is unknown for this disc - video can't be decrypted error after dragging the extracted content to C:\Users\XXX\.MakeMKV folder.
The KEYDB entry also needs a VUK, i.e. a "| V |" field, which AFAICT the disk's current entry does not have. I suspect that keydb_helper has jumped the gun slightly with that comment, but am optimistic that the VUK will appear soonish nonetheless... ;).
Happycy
Post by Happycy » Mon Dec 02, 2024 9:23 pm
Collected the UK Deluxe 4 disc edition today and can confirm that the UHD disc it a) does not open (the other Blu Ray discs work without issue) and b) generates the same "MKB20 v77 Godzilla Minus One 343A" tgz dump file.
keydb_helper
Post by keydb_helper » Tue Dec 03, 2024 4:15 am
matheousse wrote: Mon Dec 02, 2024 2:36 pm I can see the new UHD disc in the newest keydb.cfg files (at line 58177 or thereabout), however I am still getting the The volume key is unknown for this disc - video can't be decrypted error after dragging the extracted content to C:\Users\XXX\.MakeMKV folder. Am I perhaps doing something wrong? I am also noticing that MakeMKV is downloading a new _private_data.tar archive on each attempt.
Sorry about the mix-up. Re-download the latest keydb and try again, it should be good now.
MrPenguin wrote: Mon Dec 02, 2024 2:43 pm The KEYDB entry also needs a VUK, i.e. a "| V |" field, which AFAICT the disk's current entry does not have. I suspect that keydb_helper has jumped the gun slightly with that comment, but am optimistic that the VUK will appear soonish nonetheless... ;).
Yep, it must've been a time zone issue...
Happycy wrote: Mon Dec 02, 2024 9:23 pm Collected the UK Deluxe 4 disc edition today and can confirm that the UHD disc it a) does not open (the other Blu Ray discs work without issue) and b) generates the same "MKB20 v77 Godzilla Minus One 343A" tgz dump file.
Same deal Happycy, please try with the latest keydb
matheousse
Post by matheousse » Tue Dec 03, 2024 12:02 pm
keydb_helper wrote: Tue Dec 03, 2024 4:15 am Sorry about the mix-up. Re-download the latest keydb and try again, it should be good now.
All good now, disc is being copied with the latest keydb file. Thank you!
lujan
Post by lujan » Thu Jan 02, 2025 11:58 pm
How do you download the latest keydb file?
MrPenguin
Post by MrPenguin » Fri Jan 03, 2025 12:06 am
lujan wrote: Thu Jan 02, 2025 11:58 pm How do you download the latest keydb file?
From here, probably this ZIP file.
Extract the KEYDB.cfg file from the ZIP, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
